>> RH MVPS? Adobe Community Expert is the term. There's
no such term as RH MVPS.
Right, now they are called Adobe Community Experts.
>> As soon as you open the topic in RH's editor it is
going to rewrite the code.
You know what, I don't care if RH rewrites the code, just as
long as RH leaves the result appearance looking nice, i.e., it
doesn't smash up the appearance .
>> Go back to your original post here. What is it that
is missing in the RH editor? It will not be the cleaner code. RH7
cleaned up a lot and I expect more from RH8. But until then RH will
rewrite the code so I cannot see the benefit.
It's been a while now before I gave up in disgust, and went
to writing in Word. But I had expected to be able to work in WSYWYG
like in MEW or Word, with powerful style management. I expected
there to be an easy access Styles side pane. There is not. The
numbered lists were not reliable; they restarted when they were not
supposed to. Both numbered and bulleted lists get confused about
their indentation. It's lucky that I once taught myself MEW with
HTML/CSS , so after a short refresher I could go into the HTML view
and clean up all the code and make the lists the way they are
supposed to be. But since I am at a new client and only working
there at 100 hr/month, I had to show some real content output, and
fast, and so I had no more time for RH trial and error. So I went
back to Word (-- 2007, which I also did not know, but since I am
(supposed to be) a Word 2003 guru I knew what I was looking for and
that all the features are supposed to exist -- ) and wrote my first
drafts with that.
Actually, I am so shocked at RH's bad WSYWGY editor, if I had
any choice I would recommend to my client to look for something
better (if such a thing exists -- dare I mention Flare...), but
since RH is an important TW skill, I want to add it to my skills
list. So if my client has recommended using RH, this is a good
opportunity to learn RH on their account.
I have a feeling that I am eventually going to make a full
circle, i.e., either I won't find cheap/free HTML editor taht does
want I want, or even if I do, I will eventually run into the
problems you mention, and I will end up writing in raw HTML, just
as you say.
Actually, on 2nd thoughts, I also have to be honest with my
client, and I don't think they would be happy to hear that a guy
who takes over from me at some point, or is hired in addition to
me, would have to write HTML/CSS. They would want to hear that
there is some type of WSYWYG solution for RH, either internal or
external.
Tnx,
- avi
