Hi All,
I was able to setup CF9 with SSL in the pass using this https://forums.adobe.com/thread/1330662
Getting an error using Firefox 53.0.2 when I open my site https://localhost:9100/mySite
localhost:9100 uses an invalid security certificate.
The certificate is not trusted because it is self-signed.
The certificate is not valid for the name localhost.
Error code: SEC_ERROR_UNKNOWN_ISSUER
Adding the exception doesn't fix the issue because I cannot use my site with https.
Any ideas about this issue?
Best
JFB
I'm not sure what you mean by "adding the exception doesn't fix the issue because I cannot use my site with https". What exactly happens when you add the exception? Do you get the same error after adding it as you got before adding it?
Also, you might have another problem which won't be so easy to fix. The version of Java used by CF 9 is OLD. It doesn't support modern ciphers. Firefox may not allow you to use the older ciphers, once you fix the first problem.
Is there a reason you can't just upgrade to CF 11 or CF 2016 for development?
Dave Watts, CTO, Fig Leaf Software
Thanks for your reply and help.
"What exactly happens when you add the exception? Do you get the same error after adding it as you got before adding it?"
I get a different error: Connection is not secure, SSL_ERROR_INTERNAL_ERROR_ALERT
"The version of Java used by CF 9 is OLD"
Ok, Let me upgrade to CF11. Can I do the same steps using CF11?
Best,
Hi All,
I have CF11 installed with the latest update 11.
Anyone configured CF11 using https?
I was able to configure ColdFusion server over SSL follow below mentioned steps:
1. Create Keystore:
Keytool -genkey -keyalg RSA -keystore websocket.crt -storepass changeit -alias wss -keypass changeit -validity 365
2. Configure ColdFusion to run over SSL port:
i got error file not found when I try to use the https for my site as:
https://127.0.0.1:8443/mySite/index.cfm​
My site https call is pointing to my C:\ColdFusion11\cfusion\wwwroot instead of my IIS folder C:\inetpub\wwwroot
How can I fix this issue?
