I recently purchased a Canon Rebel T6. When I try to import the images directly from the camera, using Lightroom CC's Import feature, the images stored in RAW format are not found. Any jpg images are found an can be imported. I can however copy the RAW files to disk, using Canon's software, and import them into Lightroom. Both Lightroom CC and Camera Raw are updated to the latest version. Note, I also have an Olympus camera, and Lightroom can import the RAW files from this camera just fine.
Any suggestions as to why Lightroom cannot find the RAW files on the Canon camera?
Please confirm exactly which version of Lightroom CC you are running.
In Lightroom, click Help > System Info. What does the first line "Lightroom version" say in full?
The version number is: Lightroom version: CC 2015.10 [ 1111918 ]
If you are connecting the camera directly to the computer, try using a card reader instead. In the long run, you will be much happier using the card reader as the card readers are faster, less error prone, require no special device drivers, and do not drain the camera batteries.
