Does anybody know how to fix this cursor issue permanently. The circle showing the area that my tool will affect is no longer visible, only the the small cross. Please see below points for more information:
1. It's definitely not fixed by the cap locks key. (When I toggle between caps lock on and off the circle shows up for a second and disappears again.)
2. I attempted to fix the problem in the preferences and that did not work. I'm on normal brush mode. I have tried selecting "normal brush tip" as well as "full size brush tip" and have also tried deselecting "show cross hair in brush tip" and "show only cross hair in painting"
3. I'm having the issue in Photoshop using an iMac (OS Sierra version 10.12.4). The Apple update seems to be messing everything up. (Not just with Adobe).
Have you tried resetting all tools and your User ID Photoshop preferences? Have you checked Apple's site?
I have the same issue with my PC and I have gone thru preferences. They are set appropriately and I have restarted PS. Sometimes the issue will go away but not always. It really does make the brush tip hard to use.
