Hello, i am using AIMP Skin Editor to make AIMP player skins.
there is an option to make Spectrum Display using Images Frames like this picture.
the image frames interacts depending on the music frequency like this gif below,
i want to do the same using After Effect to create a logo that interacts to music.
Put the sequence in a pre-comp, use time remapping. Read the help.
Mylenium
Thank you Mylenium , i don't know but i think that's not what I'm looking for
If you have pre-exoisting graphics representing the different states it is the right method. If you need something else you have to explain better and in more detail. Of course there's a zillion ways to create stuff from scratch in AE just as well.
Mylenium
Thank you again Mylwnium , my question is : if i have png sequence , how i can make after effect change the png frames by audio frequency ? "audio keyframe - amplitude in after effect
like this
After Effects Quick Tutorial - Triangle Audio Spectrum Effect [HD] - YouTube
and
After Effects Tutorial: Audio React Anything - YouTube
but as i said, using png sequence, and just make AE change png frame by audio frequency .
It doesn't work any different with time-remapping than it does with any other property type, only the value ranges differ, of course.
Mylenium
Hi ANA-FREE,
Did Mylenium help you solve your issue, or do you still need help? If you solved it, what worked?
Kevin
