Hi All,
I have download the Echosign Rest Client API and consume the same in my Asp.Net web application. Can you tell me, How to create Access Token? I have passed the required parameter to below method but Access token is null.
/// <summary>
/// Initialize EchosignREST without Access Token. Must call Authorize() after initialization to acquire Access Token.
/// </summary>
/// <param name="apiUrl">API url returned from the authorization request URL</param>
/// <param name="clientId">Application/Client ID</param>
/// <param name="secretId">Client Secret</param>
public EchosignREST(string apiUrl, string clientId, string secretId)
this.apiUrl = apiUrl;
this.clientId = clientId;
this.secretId = secretId;
client = new HttpClient();
client.BaseAddress = new Uri(apiUrl);
How to access below method without creating Access Token by above method?
/// <summary>
/// Obtain Access Token for the Echosign REST API (use only if you don't already have a Refresh Token, or if it is expired)
/// </summary>
/// <param name="authCode">Authorization code received from the authorization request</param>
/// <param name="redirect_uri">Redirect URI matching the one specified in the authorization request</param>
/// <returns></returns>
public async Task Authorize(string authCode, string redirect_uri)
using (HttpContent content = new FormUrlEncodedContent(new List<KeyValuePair<string, string>>
new KeyValuePair<string, string>("grant_type", "authorization_code"),
new KeyValuePair<string, string>("client_id", clientId),
new KeyValuePair<string, string>("client_secret", secretId),
new KeyValuePair<string, string>("code", authCode),
new KeyValuePair<string, string>("redirect_uri", redirect_uri)
HttpResponseMessage result = await client.PostAsync("oauth/token", content).ConfigureAwait(false);
if (result.IsSuccessStatusCode)
string response = await result.Content.ReadAsStringAsync();
TokenResponse tokenObj = JsonConvert.DeserializeObject<TokenResponse>(response);
this.accessToken = tokenObj.access_token;
this.accessTokenExpires = tokenObj.expires_in;
this.refreshToken = tokenObj.refresh_token;
client.DefaultRequestHeaders.Remove("Access-Token");
client.DefaultRequestHeaders.Add("Access-Token", accessToken);
else
string response = await result.Content.ReadAsStringAsync().ConfigureAwait(false);
HandleError(result.StatusCode, response, true);
Thanks & Regards
Poomani Sankaran
Have something to add?
