Gday,
I am running an EVGA GTX 1060 FTW+ active with an EIZO CS2730. I need to set up two things:
1. Have a 10 bit workflow
2. Set up a correct rec709 color space to work in
Is anyone experienced in that workflow? I am using my system for video editing and color grading within premiere pro CC 2017. I am running windows 10 pro with the latest nvidia driver.
Does my graphic card support 10 bit? Only the displayport?
Also what are the correct rec709 values? EIZO ColorNavigator software does not realy have a rec709 preset installed so I found this:
Is that the correct one?
I run through the calibration process with ColorNavigator and SPYDER 5 PRO. Looks fine so far. But did I use the correct profile or shall l calibrate manually? But where do i get the correct color profile settings? There are some discussion about the correct gamma or 2.2 or 2.6 and other values which is a bit confusing.
Really appreciate some advise. Thanks, Alex
PrPro just works in an assumed stock-standard Rec709. It would be nice to have some settings such as both AfterEffects and Resolve have, but ... currently ... we don't have those options. There is a list I've seen of the "standard" specs for Rec709, but I don't remember the mainline gamma setting for that space.
To get 10-bit display to a monitor typically requires the use of an output box from the computer ... BlackMagic, Kona, and Aja all make the things.
My colorist friends tend to have SPENDY ... as in 2-5K USD ... calibration setups. And every six months, have a service come in and fully calibrate plus calibrate their own gear. Or ship the gear to the manufacturer for re-calibration. I'm not capable of justifying that sort of expense. Judging yours is above my experience level.
And you will probably need to do at least a manual check or verification of your screen's output. With an appropriate sensitometer & software setup.
Neil
Thank you Neil. I've found a good color profile now in which I did some slight adjustments to the gamma level and wrote it to my monitor hardware. Looks good so far
I hope to get the 10 bit working on my GTX 1060 with a DP cable. Will be here tomorrow and can say more then.
Do post the results!
Neil
Hi Neil,
got my DP cable today and everything works like a charm. Went into the NVIDIA panel and simply switched to 10bit. With the true 10bit EIZO monitor, colors look great. So no need to get a quadro I am sure if they 1060 does output 10bit. But i knew I did something right choosing EVGA for the second time.
Awesome news. The Quadro's are pretty expensive, and even colorists try to avoid them, but for 10-bit output, it seemed necessary. 10-bit directly out of a GTX card to a 10-bit monitor ... sweet!
Neil
are you sure that you really have 10bpc channel working on the EIZO monitor?
The reason I ask is that you will get pretty pictures on the Monitor but that is not the same as them actually being 10bit.
To confirm you might want to try 10 bit gradient test patterns. Somebody posted on avorums:
https://www.avsforum.com/forum/139-display-calibration/2269338-10-bit-gradient-test-patterns.html
You may have to buy a QUADRO card after all.
I hope ADOBE/NVIDIA do support 10bpc on on the 10*0 cards
