I'm using an old version of Lightroom (2.7), and cannot seem to find anywhere to edit the watermark that I want placed on my images. Anyone have experience with this version that can help? I'd like to change the size of the text of the watermark and the opacity.
I'm using mac operating system, a lot of the google searches I've done have told me to click on lightroom in the top left corner, and then go to 'edit watermark', however no such option exists for me.
When in doubt, consult the documentation http://help.adobe.com/en_US/Lightroom/2.0/lightroom_2_help.pdf
Specifically see page 127.
I'm trying to remember, I'm pretty sure that version 2 of Lightroom did not have watermarking capabilities (as confirmed by Wikipedia, if you believe they are correct)
Well, I am able to add a watermark, I just can't edit the settings of it - if that makes sense. It shows up, it's just tiny and super transparent.
How do you add a watermark?
In library mode with a photo selected, on the left hand side you can expand the 'metadata' option and write what your copyright will display, and then in your export options, under metadata you can do 'add copyright watermark'. That seems to be it, I can't find anywhere to modify how it's displayed.
Are you using a plug-in called Mogrify?
I am not
Show me a screen capture the watermark option in the Export Dialog box
Also show me a screen capture that confirms the version number of Lightroom.
Meta data info on the right
Export options
Lightroom version
Thank you sir, much appreciated.
Straight from adobe:
The copyright watermark appears in the lower-left corner of the exported photo. The size, placement, and appearance of the watermark cannot be edited or customized.
