HI all, is there a quick way to insert social media icons for Twitter, Facebook .into my document in InDesign?
Do I have to download them and insert as an image or I heard there was a special font, social pro or something, I can use which when you type in the F or T it automatically changes it to the Facebook and Twitter symbol?
Thanks in advance.
Both are possible (although I don't know what font that would be; technically at least it's not a problem).
Advantage of images: they typically are in the correct colors. A font would initially take on your main text color, and you have to manually set the correct color. You'd also have a problem with multi-color icons.
Advantage of a font: unless it's an extremely bad one, it's all in vectors. However, per definition, you lose the correct coloring (I don't believe current InDesigns already support colored fonts).
A typical freshly downloaded icon that looks just fine in your web browser, has technically way too small a resolution to be printed smoothly. You could use it anyway (based on the pragmatic point of view "because that is exactly what it looks like"), or hunt for a larger version – in which case you are best off hunting for a vector version, rather than a higher resolution bitmap.
Or maybe using something like Re: Auto replace text with an object if you have multiple instances where you wish to replace...
-Aman
Hi
Both Facebook and Twitter allow you to download their logo in a vector format (.EPS)
I believe that would be the best way to import them: no quality loss and official colors.
Besides, guidelines are also available. You might find them useful.
