Trying to modifiy the Colors on AddGuides Script?
Advocate ,
May 18, 2017 May 18, 2017
Hello everyone. I have already asked about changing colors of guides -->Is there a way to have multiple color guides? <-- but I am having trouble adapting it to this script.  I have been using AddGuides.jsx for a while now and i have a few changes that i'm trying to do but cant seem to make them work.  I'm trying to get my radiobuttons i created to *when selected* change the default color of the guides to Red, Blue, black etc.. I added lines 89-96 + 198-209 so the buttons are showing up i'm just not sure how to get them to acutally change colors.  Now i have added Lines 403 and 410 and that will change the color but i'm wanting the color to only change if my radiobuttons are selected. And right now i have lines 403+410 on 5 different scripts (with different RGB values on each).  I then merged these scripts into another scriptUI i made and i can select the colors from there.  But his is an extra step i'm trying to get rid of.  I would like it all to be in this one script.
//AddGuides.jsx
//An InDesign JavaScript
@@@BUILDINFO@@@ "AddGuides.jsx" 3.0.0.0 14 December 2009
//This script draws guides around the selected object or objects.
//Choose Visible Bounds to consider the stroke weight of the paths when placing the guides,
//or choose Geometric Bounds to ignore the stroke weight when placing the guides
//Choose Each Item to position the guides around individual items in the selection,
//or Entire Selection to position the guides around the selection as a whole.
//This script also includes an alternative dialog box for the script. This dialog was
//created using the ExtendScript ScriptUI component. ScriptUI lacks some of the useful
//controls that the InDesign dialog object offers, but it can be used to create interactive
//dialog boxes and panels.
//For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
//Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com.
main();
function main(){
    //Make certain that user interaction (display of dialogs, etc.) is turned on.
    app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
    var myObjectList = new Array;
    if (app.documents.length != 0){
        if (app.selection.length != 0){
            for(var myCounter = 0;myCounter < app.selection.length; myCounter++){
                switch (app.selection[myCounter].constructor.name){
                    case "Rectangle":
                    case "Oval":
                    case "Polygon":
                    case "TextFrame":
                    case "Group":
                    case "Button":
                    case "GraphicLine":
                        myObjectList.push(app.selection[myCounter]);
                        break;
            if (myObjectList.length != 0){
                var myOldXUnits = app.documents.item(0).viewPreferences.horizontalMeasurementUnits;
                var myOldYUnits = app.documents.item(0).viewPreferences.verticalMeasurementUnits;
                app.documents.item(0).viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
                app.documents.item(0).viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
                myDisplayDialog(myObjectList);
                //Comment out the previous line and uncomment the following line to use a ScriptUI dialog.
                //myDisplayScriptUIDialog(myObjectList);
                app.documents.item(0).viewPreferences.horizontalMeasurementUnits = myOldXUnits;
                app.documents.item(0).viewPreferences.verticalMeasurementUnits = myOldYUnits;
            else{
                alert ("Please select a page item and try again.");
        else{
            alert ("Please select an object and try again.");
    else{
        alert ("Please open a document, select an object, and try again.");
function myDisplayDialog(myObjectList){
    var myRangeButtons, myBasedOnButtons;
    var myLabelWidth = 100;
    var myDialog = app.dialogs.add({name:"AddGuides"});
    with(myDialog){
        with(dialogColumns.add()){
            with(borderPanels.add()){
                staticTexts.add({staticLabel:"Add Guides At:"});
                    var myTopCheckbox = checkboxControls.add({staticLabel:"&Top", checkedState:true});
                    var myLeftCheckbox = checkboxControls.add({staticLabel:"&Left", checkedState:true});
                    var myBottomCheckbox = checkboxControls.add({staticLabel:"&Bottom", checkedState:true});
                    var myRightCheckbox = checkboxControls.add({staticLabel:"&Right", checkedState:true});
                    var myXCenterCheckbox = checkboxControls.add({staticLabel:"&Horizontal Center", checkedState:false});
                    var myYCenterCheckbox = checkboxControls.add({staticLabel:"&Vertical Center", checkedState:false});
                    var myXPointCheckbox = checkboxControls.add({staticLabel:"Path Point Hori&zontal Anchor", checkedState:false});
                    var myYPointCheckbox = checkboxControls.add({staticLabel:"Path Point Verti&cal Anchor", checkedState:false});
                staticTexts.add({staticLabel:"Add Guides Around:"});
                with(myRangeButtons = radiobuttonGroups.add()){
                    radiobuttonControls.add({staticLabel:"Each &Object", checkedState:true, minWidth:156});
                    radiobuttonControls.add({staticLabel:"Entire &Selection"});
                staticTexts.add({staticLabel:"Guide Color:"});
                    radiobuttonControls.add({staticLabel:"Red", checkedState:false, minWidth:156});
                    radiobuttonControls.add({staticLabel:"Blue"});
                    radiobuttonControls.add({staticLabel:"Black"});
                    with(dialogRows.add()){
                            staticTexts.add({staticLabel:"Guides Based On:"});
                            with(myBasedOnButtons = radiobuttonGroups.add()){
                                radiobuttonControls.add({staticLabel:"&Geometric Bounds", checkedState:true, minWidth:160});
                                radiobuttonControls.add({staticLabel:"V&isible Bounds"});
                            staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
                            var myXOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
                            staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
                            var myYOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
    myReturn = myDialog.show();
    if (myReturn == true){
        //Get control values from the dialog box.
        var myTop = myTopCheckbox.checkedState;
        var myLeft = myLeftCheckbox.checkedState;
        var myBottom = myBottomCheckbox.checkedState;
        var myRight = myRightCheckbox.checkedState;
        var myXCenter = myXCenterCheckbox.checkedState;
        var myYCenter = myYCenterCheckbox.checkedState;
        var myXPoint = myXPointCheckbox.checkedState;
        var myYPoint = myYPointCheckbox.checkedState;
        var myBasedOn = myBasedOnButtons.selectedButton;
        var myRange = myRangeButtons.selectedButton;
        var myXOffset = myXOffsetField.editValue;
        var myYOffset = myYOffsetField.editValue;
        //Remove the dialog box from memory.
        myDialog.destroy();
        if(myTop+myLeft+myBottom+myRight+myXCenter+myYCenter+myXPoint+myYPoint !=0){
            myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList);
        else{
            alert("No guides were specified.");
    else{
        myDialog.destroy();
//ScriptUI version of the above dialog box.
function myDisplayScriptUIDialog(myObjectList){
    var myBasedOn, myRange;
    var myDialog = new Window('dialog', 'AddGuides');
    with(myDialog){
        alignChildren = 'fill';
        var myGuideTypesPanel = add('panel', undefined, "Add Guides At:");
        with(myGuideTypesPanel){
            orientation = 'column';
            alignChildren = 'left';
            margins = [12, 16, 12, 6];
            spacing = 4;
            myDialog.myTopCheckbox = add('checkbox', undefined, "Top");
            myDialog.myTopCheckbox.value = true;
            myDialog.myLeftCheckbox = add('checkbox', undefined, "Left");
            myDialog.myLeftCheckbox.value = true;
            myDialog.myBottomCheckbox = add('checkbox', undefined, "Bottom");
            myDialog.myBottomCheckbox.value = true;
            myDialog.myRightCheckbox = add('checkbox', undefined, "Right");
            myDialog.myRightCheckbox.value = true;
            myDialog.myXCenterCheckbox = add('checkbox', undefined, "Horizontal Center");
            myDialog.myXCenterCheckbox.value = true;
            myDialog.myYCenterCheckbox = add('checkbox', undefined, "Vertical Center");
            myDialog.myYCenterCheckbox.value = true;
            myDialog.myXPointCheckbox = add('checkbox', undefined, "Path Point Horizontal Anchor");
            myDialog.myXPointCheckbox.value = true;
            myDialog.myYPointCheckbox = add('checkbox', undefined, "Path Point Vertical Anchor");
            myDialog.myYPointCheckbox.value = true;
        var myGuideLocationPanel = add('panel', undefined, "Add Guides Around:");
        with(myGuideLocationPanel){
            margins = [12, 14, 12, 6];
            spacing = 4;
            myDialog.myEachObjectRadioButton = add('radiobutton', undefined, "Each Object");
            myDialog.myEachObjectRadioButton.value = true;
            myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Entire Selection");
        var myColorGuideLocationPanel = add('panel', undefined, "Guide Colors:");
        with(myColorGuideLocationPanel){
            guideColor = [255,255,150] ;
            spacing = 4;
            myDialog.myEachObjectRadioButton = add('radiobutton', undefined, "Red");
            myDialog.myEachObjectRadioButton.value = false;
            myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Blue");
            myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Black");
        var myGuidesBasedOnPanel = add('panel', undefined, "Add Guides Based On:");
        with(myGuidesBasedOnPanel){
            spacing = 4;
            myDialog.myGeometricBoundsRadioButton = add('radiobutton', undefined, "Geometric Bounds");
            myDialog.myGeometricBoundsRadioButton.value = true;
            myDialog.myVisibleBoundsRadioButton = add('radiobutton', undefined, "Visible Bounds");
            with(add('group')){
                orientation = 'row';
                alignChildren = 'center';
                spacing = 2;
                with(add('group')){
                    alignChildren = 'right';
                    var myXOffsetLabel = add('statictext', undefined, "Horizontal Offset:");
                    var myYOffsetLabel = add('statictext', undefined, "Vertical Offset:");
                with(add('group')){
                    myDialog.myXOffsetField = add('edittext', undefined, "0", {enterKeySignalsOnChange:false});
                    myDialog.myXOffsetField.characters = 7;
                    myDialog.myXOffsetField.justify = "right";
                    myXOffsetField.onChange = function(){
                        if(myValidateNumber(myXOffsetField.text)==false){
                            alert("Invalid numeric entry!");
                            myDialog.myXOffsetField.text = "0";
                    myDialog.myYOffsetField = add('edittext', undefined, "0");
                    myDialog.myYOffsetField.justify = "right";
                    myDialog.myYOffsetField.characters = 7;
                    myYOffsetField.onChange = function(){
                        if(myValidateNumber(myYOffsetField.text)==false){
                            myDialog.myYOffsetField.text = "0";
                with(add('group')){
                    add('statictext', undefined, "points");
        with(add('group')){
            alignment = 'right';
            myDialog.myCloseButton = add('button', undefined, "Close", {name:'cancel'});
            myDialog.myCloseButton.onClick = function(){myDialog.close()};
            myDialog.myOKButton = add('button', undefined, "OK", {name:'ok'});
    var myReturn = myDialog.show();
        with(myDialog){
            var myTop = myTopCheckbox.value;
            var myLeft = myLeftCheckbox.value;
            var myBottom = myBottomCheckbox.value;
            var myRight = myRightCheckbox.value;
            var myXCenter = myXCenterCheckbox.value;
            var myYCenter = myYCenterCheckbox.value;
            var myXPoint = myXPointCheckbox.value;
            var myYPoint = myYPointCheckbox.value;
            var myXOffset = parseFloat(myXOffsetField.text);
            var myYOffset = parseFloat(myYOffsetField.text);
            if(myGeometricBoundsRadioButton.value == true){
                myBasedOn = 0;
            else{
                myBasedOn = 1;
            if(myEachObjectRadioButton.value == true){
                myRange = 0;
            else{
                myRange = 1;
        myDialog.close();
        else{
    else{
        myDialog.close();
function myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList){
    var myLayer, myCounter;
    var myOldRulerOrigin = app.activeDocument.viewPreferences.rulerOrigin;
    app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.spineOrigin;
    //Create a layer to hold the printers marks (if it does not already exist).
    myLayer = app.activeDocument.layers.item("Guides");
    try{
        myLayerName = myLayer.name;
    catch (myError){
        myLayer = app.activeDocument.layers.add({name:"Guides"});
    //Process the objects in the selection.
    for(myCounter = 0; myCounter < myObjectList.length; myCounter ++){
        var myObject = myObjectList[myCounter];
        if (myBasedOn == 0){
            myBounds = myObject.geometricBounds;
        else{
            myBounds = myObject.visibleBounds;
        //Draw guides at path point locations, if necessary.
        if ((myXPoint == true)||(myYPoint == true)){
            myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint);
        //Set up some initial bounding box values.
        if ((myRange != 0)&&(myCounter==0)){
            myX1 = myBounds[1];
            myY1 = myBounds[0];
            myX2 = myBounds[3];
            myY2 = myBounds[2];
        if(myRange == 0){
            myDrawGuides (myBounds[1], myBounds[0], myBounds[3], myBounds[2], myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
        else{
            //Compare the bounds values to the stored bounds.
            //If a given bounds value is less than (for x1 and y1) or
            //greater than (for x2 and y2) the stored value,
            //then replace the stored value with the bounds value.
            if (myBounds[0] < myY1){
                myY1 = myBounds[0];
            if (myBounds[1] < myX1){
                myX1 = myBounds[1];
            if (myBounds[2] > myY2){
                myY2 = myBounds[2];
            if (myBounds[3] > myX2){
                myX2 = myBounds[3];
    if(myRange != 0){
        myDrawGuides (myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
    app.activeDocument.viewPreferences.rulerOrigin = myOldRulerOrigin;
function myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint){
    for(var myPathCounter = 0; myPathCounter < myObject.paths.length; myPathCounter++){
        for(var myPointCounter = 0; myPointCounter < myObject.paths.item(myPathCounter).pathPoints.length; myPointCounter ++){
            if(myXPoint==true){
                myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[0], 1);
            if(myYPoint==true){
                myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[1], 0);
function myDrawGuides(myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset){
    if (myTop == true){
        myDrawGuide(myY1 - myYOffset, 0);
    if (myLeft == true){
        myDrawGuide(myX1 - myXOffset, 1);
    if (myBottom == true){
        myDrawGuide(myY2 + myYOffset, 0);
    if (myRight == true){
        myDrawGuide(myX2 + myXOffset, 1);
    if (myXCenter == true){
        myDrawGuide(myX1+((myX2-myX1)/2), 1);
    if (myYCenter == true){
        myDrawGuide(myY1+((myY2-myY1)/2), 0);
function myDrawGuide(myGuideLocation, myGuideOrientation){
    var myLayer = app.activeDocument.layers.item("Guides");
    with(app.activeWindow.activeSpread){
        if(myGuideOrientation == 0){
            with (guides.add(myLayer, undefined, undefined)){
                orientation=HorizontalOrVertical.horizontal;
//                guideColor = [255,0,0] ;
                location=myGuideLocation;
        else{
                orientation=HorizontalOrVertical.vertical;
function  myValidateNumber(myString){
    var myRegExp  =  /(^-?\d\d*\.\d*$)|(^-?\d\d*$)|(^-?\.\d\d*$)/;
    return myRegExp.test(myString);
I also tried to add this to lines 415-433 but it didn't change the color. and this is not specific to each seperate Radiobutton.
function myColorDrawGuide(myColorGuideLocation, myColorGuideOrientation){
        else{
Scripting
709
Community Beginner , May 22, 2017 May 22, 2017
Do you want this effect?
(你是想要這個效果嗎?)
//AddGuides.jsx
Advocate ,
The Script in the above links is below:
  1. var doc = app.documents[0];
  2. app.documents[0].spreads[0].guides.add
  3.
  4.     {
  5.         guideColor : [255,0,0] ,
  6.         guideType : GuideTypeOptions.RULER ,
  7.         location : "10 mm" ,
  8.         orientation : HorizontalOrVertical.VERTICAL ,
  9.         fitToPage : true ,
  10.         itemLayer : doc.layers[0]
  11.     }
  12.
  13. );
Advocate ,
I Should point out i am only interested in guideColor I may add Fit to page later but Color is the important one.
(你是想要這個效果嗎?)
//AddGuides.jsx
main();
function main(){
                    case "Rectangle":
                    case "Oval":
                    case "Polygon":
                    case "TextFrame":
                    case "Group":
                    case "Button":
                    case "GraphicLine":
                        break;
            else{
        else{
    else{
    with(myDialog){
                with(myColorRangeButtons = radiobuttonGroups.add()){
                    radiobuttonControls.add({staticLabel:"Red", checkedState:true, minWidth:156});
        var myColorRange = myColorRangeButtons.selectedButton;
        switch (myColorRange){
            case 0:
                MY_GUIDE_COLOR = [255, 0, 0]
                break;
            case 1:
                MY_GUIDE_COLOR = [0, 0, 255]
                break;
            case 2:
                MY_GUIDE_COLOR = [0, 0, 0]
                break;
        myDialog.destroy();
        else{
    else{
        myDialog.destroy();
    with(myDialog){
            spacing = 4;
            spacing = 4;
            spacing = 4;
            spacing = 4;
            with(add('group')){
                spacing = 2;
                with(add('group')){
                with(add('group')){
                with(add('group')){
        with(add('group')){
        with(myDialog){
                myBasedOn = 0;
            else{
                myBasedOn = 1;
                myRange = 0;
            else{
                myRange = 1;
        myDialog.close();
        else{
    else{
        myDialog.close();
    try{
    catch (myError){
        else{
            myX1 = myBounds[1];
            myY1 = myBounds[0];
            myX2 = myBounds[3];
            myY2 = myBounds[2];
        if(myRange == 0){
        else{
                myY1 = myBounds[0];
                myX1 = myBounds[1];
                myY2 = myBounds[2];
                myX2 = myBounds[3];
    if(myRange != 0){
            if(myXPoint==true){
            if(myYPoint==true){
    if (myTop == true){
                guideColor = MY_GUIDE_COLOR;
        else{
Advocate ,
May 23, 2017 May 23, 2017
Thank you so much this is exactly what i've been trying to do for the past 2 days.  I'm gonna study this script so I can see what you did to make it work and what i was doing wrong.
Advocate ,
I was on the right track yesterday.  I had the radio button control in the wrong place i had it in "SCRIPT UI" portion i needed to move it up.  again.  Thank you
