Gpu Acceleration r9 280x
May 23, 2017 May 23, 2017
I can't change the renderer settings in premire
[Moderator note: moved to best forum]
2.4K
Valorous Hero , May 28, 2017 May 28, 2017
try disabling the intel graphics, sometimes it conflicts with the amd video card when premiere is looking for a video card to use.
May 27, 2017 May 27, 2017
anyone ?
What are the specs of your computer?
cpu; i5 4470
ram ; 8gb (1 stick)
gpu: r9 280x
You have a weakling CPU and a both too little and too-low-throughput memory subsystem. With only one stick of RAM, you're doing only single channel. You cannot get dual-channel out of only one stick of RAM; it's completely impossible.
Also, you did not specify any disk(s) that are installed, and any disks that are connected.
By the way, the i5-4470 does not exist. Did you mean an i5-4460? I5-4570? I5-4670?
Jun 06, 2017 Jun 06, 2017
Yeah you are right i have the 4460 but i dont see what me weak computrer has to do with that problem, i've diabled the IGPU and i can select opengl acceleration. however i dont really notice any performence improvment at all. thank you for the help.
I believe you have to select OpenCL as OpenGL has nothing to do with Adobe's GPU acceleration.
Also because you do have that i5-4460, as it does not support hyperthreading it really hurts Premiere Pro performance
Valorous Hero ,
I have tested an R9-280X and it works see my test results here.  Try Ronin's suggestion.
RoninEdits has a good suggestion. If you run GPUSniffer at the command prompt window, and you find both the AMD GPU and the integrated Intel IGP listed and enabled, you should see an error message "Not chosen because of initialization failure." That would have forced Premiere Pro to render in software-only mode.
