Someone will help!!!
We need workflow, system and AE version details down to the last decimal point. There's no way to answer a question with details.
I also received the Creators update yesterday, after the update i couldn't run Adobe After effects at all, at launch it shows "After effects has stopped working". Also premiere showed the same message after opening any project.
I tried creating a new user & Uninstalling/reinstalling the programs with no luck.
I Just rolled back the update because i need ِAfter effect for school, i hope this can be fixed soon.
Dell Xps 9560
Intel i7 7700HQ
Nvidia GTX1050 , Intel HD graphics 630
16GB Ram
After the Windows 10 Creator update, I'm suddenly confronted with these two errors:
1. After effects hangs up at the "initializing media core" during start up. I need to reboot (a few times sometimes, all seems quite random) in order it to start up.
2. "The font dictionary can't be read" error sometimes happens when it does start up..
Will any update fix this soon, or should I try to roll back the windows update?
BTO laptop |
Windows 10 PRO 10.0.15063 Build 15063 |
Intel(R) Core(TM) i7-6820HK CPU @ 2.70GHz, 2701 MHz, 4 core('s), 8 logische processor(s) |
RAM memory: 64,0 GB |
Allright, I have just uninstalled the creators update and everything seems to work fine again.. pfew.
See here how: https://betanews.com/2017/04/11/how-to-rollback-and-uninstall-windows-10-creators-update/
I'm also currently blocking any further windows updates, but lets hope this stuff will get fixed soon..
Hi Bas M,
Do you have Extensis Suitcase Fusion installed by any chance? If so, can you try uninstalling it? This fixed the issue for at least one other customer.
Kevin
Hi Micheaeloo,
Do you have Extensis Suitcase Fusion installed? If so, can you try uninstalling it for a possible solution?
Kevin
Unfortunately, I don't have it installed, I rolled back the Creators update from my system, so I can't really troubleshoot this problem anymore, but soon I will have to.
I logged in again to windows account.
Later, same to adobe account.
After one hour everything went back to normal.
adriand81178245 Can you pleas describe what was your problem with after effects?
Just after update creator windows after effects did not want to run.
A message appeared. After effects stopped working.
So, the new version of Windows is out and After Effects isn't working on it for you, yes?
It sounds like you did an update and not a clean install. This can cause issues. You might try uninstalling AE and reinstalling it.
Hi Szalam, i actually tried that, and the issue is both of CC2017 and CC2014 have the exact same problem.. and Microsoft support just said to run compatibility troubleshooting, which is a joke
Clean install is very time consuming, i have one laptop with one SSD. formatting well delay my work a lot.
If updating to the Creator's Edition made all versions of After Effects stop working, I don't know of any way to help you. You can try contacting Adobe support. If you find a good solution, please let us know.
Roll back your GPU driver to the 3rd latest.
Hi AdrianD,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
Kevin, just a heads up that I was having consistent crashes when loading projects since the Creator update on Windows. I finally tracked down the problem, which was some sort of conflict with Extensis Suitcase Fusion. When I uninstalled Suitcase Fusion, the crashes ceased.
I can't speak to the issue of importing one project into another, as I haven't tried that since uninstalling Suitcase Fusion.
Thanks for letting us know, DeGroot Media.
Kevin
Hi AdrianD,
Do you have Extensis Suitcase Fusion installed by any chance? If so, can you try uninstalling it for a possible fix?
Kevin
