How do I go about making an effects preset in AE and then batch appying that to all clips from a folder & output to separate files, I assume I use media encoder somehow?
You don't. Such a workflow would require some quite extensive scripting to create the comps, add the layers, apply effects, add to the render queue...
Mylenium
I had assumed I could just use an adjustment layer on a clip & then some how batch the clip underneath via Media Encoder.
Maybe there is a way to do this via Premiere Pro & Media encoder.
May we assume that you haven't used AE much, and that you're unaware that the only way to get stuff out of the application is by going through a comp?
I understand how it works, I just thought I may be able to use it in a batch function via Media Encoder
Hi VJ Morph,
Which effect? You can add a LUT (color grade) to clips in a batch on export. Let us know details.
Kevin
