So, have been using LR5 and have been using PSE10 as my external editor on a PC.
Sometimes I want to export to PSE as a jpeg so have set up the "additional" external editor to export the file as a jpeg and use the Ctrl/Alt/E shortcut to do so.
Fanatasic !
Now, have bought a new PC and installed LR5 and now PSE15 (10 wouldn't work on my lovely new QHD screen) and set EXACTLY the same settings.
The files appear as Tif's !!!!!! ie; it appears it is sending to the external editor and not the ADDITIONAL external editor.
The keyboard shortcut should not be any different, as it's the same version of LR and if I use the menu to get there, same result.
Pulling my hair out trying to fix it.
Can any one help please ?
Hi Johnny,
Please change the file format to "JPEG" under additional external editor settings.
Open Lightroom > Edit menu > Preferences > External Editing > Additional External Editor > File format > Set to "JPEG"
Also, please set up the additional external editor by going in Lightroom Preferences > External Editing and then try the shortcut (Ctrl+Alt+E)
Regards
Mohit
That is what I have already done !!!
It has me baffled
These are the settings I have been using (see attached file ‘capture”)
When PSE15 opens I get the msg as in attachment “could not complete”
Ensure you have selected the application in the external editing tab – see image below.
When you click the choose button navigate to:
C:\Program Files\Adobe\Photoshop Elements 15
Scroll down to the files beginning with P and select PhotoshopElementsEditor
You may get a message that it is already recognized as the main external editor app, so choose to use anyway.
After setting jpeg etc. you can click the custom drop-down arrow and save the current settings as a named preset.
Yes, that is exactly what I did from the beginning, as you can see from the attached screenshot.
Then when PSE opens I get the error msg.
