Scroll Bar has disappeared in Search Results, IE
May 24, 2017 May 24, 2017
I'm using RH 2015. I'm generating WebHelp Pro as my primary layout. I have indicated "Show Total Number of Search Results".
When reviewing my Search items in IE, it only lists a few of the search result items and no scroll bar to see the rest (see image).
However, when I look at the Search item in Chrome or Firefox, the scroll bar is visible, enabling a user to look through all results (see image).
Why is this happening and how can I fix this? Our user base primarily used IE (various versions).
Help!
398
Do you have RoboHelp Server installed on the server you are publishing to?
WebHelp Pro requires RoboHelp Server. If you don't have that, you need to use WebHelp.
Also do you have all the updates applied?
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
Yes, it’s posted to a server.
Letizia
Yes but does that server have RoboHelp Server installed? It's another piece
of software required by WebHelp Pro.
Without that, you need WebHelp, not the Pro output.
Yes, RH Server is installed. It has always worked beautifully with RH9. We upgraded to RH 2015 and only now is this an issue.
Letizia
I think this might be a version compatibility issue. I will check with
someone who can advise.
Thanks so much. I really appreciate your help!
Letizia
May 26, 2017 May 26, 2017
Sorry you haven't had a response from the people I reached out to. I will try someone else. Alternatively, perhaps check with Adobe Customer Support.
@petergrainge
May 31, 2017 May 31, 2017
Thank you Peter. I really appreciate your help. Yes, I’ll also contact them.
Thanks again!
Letizia
And yes, I’ve updated RH 2015 just days ago.
Letizia
RoboHelp Documentation
Download Adobe RoboHelp
