Hi Avi
In addition to what our friend Colum offered, I'll also offer
this:
1. RH works only on a disk drive, and not on a server. I.e., you
have to keep the images in a disk folder.
Not sure where images suddenly come into play, but okay. Yes,
RoboHelp projects (consisting of all sorts of files) should be kept
locally when working.
2. Once you have created an RH project you can't copy it to
anywhere else and make it work?
This one is almost beyond belief. I think I will have another
go at copying it and opening it from its new location.
You may copy all you like. They key to making it all work in
the end is to ensure nothing changes relative position. For
example, you can't simply copy a project from location a to
location b, then decide to relocate files within the folders of
location b outside of RoboHelp and have it work. But things should
work just fine as long as you performed a simple copy.
3. If anybody else on another PC wants to open the RH project he
has to copy it to a folder of identical name on his hard drive.
This is untrue. Unless possibly source control is in use. But
even then I believe it has more flexibility than that. RoboHelp
doesn't typically work with and enforce absolute pathing. In my
experience, one has to sort of jump through hoops to MAKE it work
that way.
Cheers... Rick
