Welcome to our community, Anish
I know you are dismayed, but Captivate probably isn't to
blame here. Think of it this way. You purchase a Ferrari and paid a
lot of money for it. The darn thing is fast but you have to
throttle it back to drive on the roads.
Well, it's sort of a similar situation. Think about the
actions you are performing. Captivate is installed and running on
your local PC. Running quite fast too. You are reporting mismatched
slides. I'm assuming that this may include blank slides and slides
where the click doesn't quite match the action. Here's what happens
and it happens most often when recording Web sites.
You have to consider the actions that occur with a Web site.
You click a link, right? But what does that link actually do? I'll
tell you what it does. It sends a command back to the Web server.
The command usually results in asking the Web server to serve up a
different page. So off the server goes, fetches the page and sends
it back to your browser, where it is then presented to you.
So Captivate sees the click and BAM! It grabs the screen. But
that screen probably hasn't fully repainted. It may be blank.
Waiting to receive the results from the server!
The bottom line here is to pay close attention to your
recording. Listen to the camera shutter sound. Note if it seems to
be mismatched to the screen activity. If so, tap the Print Screen
key to coax Captivate into adding a screen. The goal is to end up
with more screens than you need. After all, it's far easier to
remove what you don't need than it is to try and capture it after
the fact.
Cheers... Rick
