I have opened a RH for Word project using RH HTML as I was
told by several people that the HTML flavour supported hyperlinks
to files other than HTM or HTML. I used links to PDFs and when
compiled the Help File, it all worked fine. However, since I saved
my work in VSS (I am not using the Version Control facility from
RH, I simply uncheck files in VSS, work on them using RH and then
check them in.
After having checked the files in, I checked everything out
and re-opened my project: BIG MISTAKE. My TOC file must have been
corrupted as my TOC had a few topics but all with broken links, my
index was empty and worst of all, none of my hyperlinks to PDFs
work. When I compiled the HTML Help File and clicked on the
hyperlinks, it takes me to a 'This program cannot display the
webpage' page. I have managed to recover my index and TOC files by
uncompiling the Help File that I saved in Visual Source Safe (aka
the 'correct' help file, not corrupted), but I do not understand
what is going on with my hyperlinks.
Any ideas? I checked on the true code and it all seems fine.
Hyperlinks are of the type
<a href="../OG-DUB-W11 -
Instruction11.pdf">here</a> where OG-DUB-W11 -
instruction11.pdf is my PDF file and here the hotspot text.
When I compiled the 'correct' Help File (with the hyperlinks
working), I noticed that the PDFs were all incorporated in the
compiled file as they were listed in the bottom, but they are not
anymore.
I do not know what to do, can anybody help?
Thank you in advance from a person who is nearly bold from
pulling her hair due to RH use...
