Hello,
I have about 90 badges that need to be printed at a size of 13x10cm. Each of them have different names and info which need to be aligned onto printed paper in a column of three for accurate cutting.
I've yet to find a better way on aligning these graphics which comes from Photoshop other then After Effects.
The problem being, After effects seems to scale down the size or not proportionately determine the size from photoshop which is 13x10cm.
The black is representing three badges which should be aligned, but it scales down the imported photoshop files.
I'm sorry if I'm not making any sense, but please ask questions.
I submit that a forum populated with people who are good with AE and not necessarily as good with Photoshop may not be the best place to ask about this. I recommend asking in the Photoshop forum.
I'm not clear what AE even has to do with this. PS has enough alignment functions of its own and is obviously much better suited for any kind of print work.
Mylenium
Sorry, but AE is the wrong tool for the job. Stick with Photoshop.
how is there a way to automate the process on taking a hundred images, aligning them up three at a time vertical, saving it as a image and aligning the three? I didn't find anyway to do this within photoshop
