Hello All,
I want to load jsx file dynamically from the server (e.g. Through an http get call) in my premiere pro panel. How this can be achieved?
Premiere Pro version: 9.0.0
Extension Type: Panel
Thanks & Regards,
Meet Tank
I'm not sure. PProPanel declares (in its manifest) the path to one .jsx file; from within that file, it loads any others, from within its directory.
Your panel could download a .jsx file somewhere, but don't save it into your extension directory, or you'll un-sign your panel.
That downloaded file may need to be in place very early, if you want its functions to be available throughout that PPro session...
Of course, if you're calling evalScript from within your JavaScript, it doesn't matter from wh
...Copy link to clipboard
Of course, if you're calling evalScript from within your JavaScript, it doesn't matter from where you get the ExtendScript that you're evaluating...
Fetching over http is a very bad idea, this is prone to server attacks as well as man-in-the-middle attacks. There's a reason why Adobe requires Panels to be signed...
Those are valid concerns, AND...many panels' JavaScript is server-based; see the Trello example.
I asked this question 3 years ago... we have implemented loading of JSX over HTTP for our panel extension, whereby the ZXP only consists of a simple iframe, and the application itself is loaded over HTTP into the iframe.
Having said that - this is indeed a big concern in terms of security. We are currently in the process of rebuilding our panel so that all application logic is signed, sealed and delivered with the ZXP.
