HI!
PS CS6 is crashing every time that I close a file when when open in float all windows. It doesn't seem to crash otherwise. Unfortunately, float all in windows is how I need to work. It says " photoshop has closed unexpectedly". does it every time, no matter how many or few files I have open. As soon as I close a file, poof, program closes. Are you able to help me? I am on a mac OS sierra laptop 10.12.4
I know it's not my files that has been checked.
I had the program on a pc previously and it worked fine then but this is something on the mac.
Thank you,
Andrea
You should post your Mac Crash reports for your CS6 crashes. Some Mac user may be able to help you identify where your problem is.
Thanks but I'm not sure where you are referring to report mac crash.
Does anyone have any suggestions about how to fix the problem? I always like to work with arrange all in windows so it's a real problem.
When Application fail on Systems like Windows and Mac OSX the system record a Application crash report. I use Windows and know how to find and post them. You are a Mac user see how other mac users post Mac Crash reports. Then post your Photoshop Crash reports. Mac users will be able to help you with the report.
Hey!
We had the same problem at our company with new Macs. Luckily we found a solution!
You have to disable the application frame (the default grey background when no picture ist open). Its the third from the bottom in the Windows drop down menu.
