Exporting a looping walk cycle
May 27, 2017 May 27, 2017
Is it possible to export a looping walk cycle from Character Animator? I am exporting using the PNG export option, which exports the entire scene, but I would like to export only the frames that make up a complete walk cycle for my character.
693
Guru ,
Two ways I can think of off hand --
Working with the xml file might be the easiest way. Bring it into AME or Pr Pro and choose the in/out points. Then you can export as a looping animated gif.
If you want something other than a gif, you could export the selected in/out region as the video format of your choice, and then use one of the instant player apps with loop enabled.
I managed to do it through After Effects. Apparently the first few frames of the walk cycle in Character Animator is not part of the looping walk cycle, so had to cut them out.
I would be useful to be able to select a part of the timeline directly in CA, have it loop on playback and then be able to export only that segment.
Adobe Employee ,
May 30, 2017 May 30, 2017
Was your walk cycle controlled via Left/Right Arrow keys (which does have a ramp up/down phase) or set to start Immediately (which I would think would loop from the start)?
In/out range for export is a feature request we've heard before: https://character-animator.ideas.aha.io/ideas/CH-I-160
Thanks.
