Interactivity not working
May 28, 2017 May 28, 2017
I have a school project I am doing which requires interactive pdf pages
So far I have done the following but nothing has been working
Hyperlinks
Bookmarks
Buttons
I have tried setting destinations to files or urls of the files to be opened
I have been exporting as an interactive pdf but whenever I click the links the page will flash but remain on the same page
I have been doing trial and error with different methods including acrobat for 5+ hours and currently had little to no success at all
if anyone could help it would greatly appreciated and it would put my mind at ease
532
Which reader are you using?
(It's only safe to use Adobe Acrobat Reader, preferably the latest version.)
By the way, which version of InDesign and OS do you have?
I am using IndesignCC 2017
whenever the pdfs open they open via IE
as far as acrobat goes I was using Acrobat DC from creative cloud subscription
First, double- then triple-check that you chose Interactive (you probably did, but check.)
Second, solving one issue at a time, look at your Hyperlinks panel. Do you see green or red dots? Make the panel wider and post a screen shot.
https://puu.sh/w3QIZ.png
here is a screenshot, I am trying to link multiple indesign pages together.
also I have tried exporting to pdfs and linking pdfs and nothing is happening
I am still trying different methods and nothing is working
Double-click your hyperlink to show the next screen. You can copy and paste into this window. What are you linking to?
Bookmarks
Your Bookmarks panel will be filled out automatically when you generate a Table of Contents. If you are not going to use it, throw it on the pasteboard and don't format it. You can also create Bookmarks manually.
If you create a Print PDF, you need to check that you want to include Bookmarks and Hyperlinks. It not automatic. But you said you are doing Interactive.
Show a screen shot of your Bookmarks panel.
Buttons
Paste a screenshot of your button and the Button panel. Make sure you are choosing an Action from Section 1 or Section 3. The middle section has a pale gray heading indicating SWF/EPUB only, and you are making a PDF.
Buttons also work in a Print PDF as well as Interactive.
I am trying to link multiple sheets together  here is a screenshot of the first page
https://puu.sh/w423t.png
then i am trying to link the other pages to the main page
https://puu.sh/w42b9.png
note i have deleted previous hyperlinks which is why they are not showing in the second image
Text Anchor of [None]? Here's the fix:
  • Go to the other document and create the Text Anchor.
  • Click an insertion point in the other document
  • Click the Hyperlinks panel menu > New Hyperlink Destination
  • Type: Text Anchor > Name (whatever you called it)
  • Back in the first document, select your text and create a new Hyperlink to your named text anchor.
Note: if you have one, but have not used it, just select it where is says [None].
I am trying to link the text anchors however when I try to select the text anchor the only option that comes up is one
