You can save this as an AVI file in Captivate 4. See Adobe documentation here:
http://help.adobe.com/en_US/Captivate/4.0/Using/WS5b3ccc516d4fbf351e63e3d119e958285f-7fff.html
Publish the project as an AVI file
You can publish your Adobe Captivate project as an AVI file. Open the published AVI file in any of the media players that support the AVI format.
You can use any of the encoders available on your operating system for publishing. Alternatively, you can use a third party software that you have installed on your computer.
Note: All interactivity in your project is lost when you convert the project to an AVI file.
1. Select File > Publish.
2. In the Publish dialog box, select Media, and configure the following options:
Select Type
From the menu, select Video (*.avi)
Project Title
Enter a name for the AVI file without adding the extension (.avi).
Folder
Enter the full path to the folder in which to save the file, or click Browse to locate the folder.
3. Select from the following output options:
Video Format
The list of encoders available on your system is available here. Select an encoder for publishing the project in the AVI format.
Audio Format
Adobe Captivate uses pulse code modulation (PCM) for audio files. Simply put, PCM converts analog files to binary (digital) files.
The Project Information area displays useful statistics about the project including the size (resolution), number of slides, audio information, e-learning details, accessibility compliance, and playback control assigned to the project. To change any of the options listed in this area, click the blue text. To change preferences, click the Preferences button.
