How can i add a Tab Stop in a cell by insertionPoint?
May 28, 2017 May 28, 2017
Hi, All:
I have a problem,
There is a table.
There are a number of cells in the table.
There are a number of text paragraphs in the cell.
I need to add a tab stop somewhere in the text paragraph.
and so:
I want to get X point for the New Tab Stop.
My approach is as follows:
1. Move the insertion point to the target position.
2. Obtain the insertion point of the X point.
This is my code to get the X point from insertion point:
var myIP = app.selection[0]
$.writeln(getRelativeX(myIP))
function getRelativeX(myIP){
var myPG = myIP.paragraphs[0]
if(myPG.justification != Justification.LEFT_ALIGN){
      var scriptString = 'myPG.justification = Justification.LEFT_ALIGN';
      var test = app.doScript(scriptString, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "getRelativeX");
      var myPGZeroPoint = myPG.horizontalOffset - myPG.leftIndent - myPG.firstLineIndent
      app.activeDocument.undo()
}else{
var myRelativeX = myIP.horizontalOffset - myPGZeroPoint
return myRelativeX
If the paragraph's alignment is not on the left will get the wrong answer.
So I change the alignment on the left and then undo.
Is there a better way? with out undo?
Thx a lot.
Scripting
574
Guru ,
Hi Hoa,
One option would be to just use the properties
IN PSEUDO CODE!
var currentJust = myPG.justification;
if !LTR {
set to LTR
do the calculation
reset myPG.justification = currentJust
However it might be better to use the undo method but with the UndoModes.AUTO_UNDO and no tag so that the undo doesn't show up on the edit history.
I somehow also feel there might well be a better way of doing it. But I can see problems with them in cases like tables.
HTH
Trevor
May 29, 2017 May 29, 2017
Hi Trevor,
Thanks for your reply.
I agree with you, change the properties will be better than use UNDO.
However, it seems to be no difference in nature.
Is it possible to get results in a calculated way?
Guru ,
If you are working with simple non transformed text frames then you can just add to the geometricBounds.
If your dealing with tables then your have to calculate the starts of the cell.
Guru ,
The fact is that the current method you are using is not going to deal with transformations.
May 30, 2017 May 30, 2017
Do you mean we had a (better / correct) way to (get cell zero point / add a tab stop at insertion point)?
Guru ,
Jun 02, 2017 Jun 02, 2017
This is the sort of getter / setter I had in mind.
function getTabStop(tabStopProperties, applyToParagraphStyle) {
    var selection, tf, ipOffset, p, tabProperties, ip, tabListLength;
    selection = app.selection[0];
    if (!selection) {
        return 'No Selection';
    if (!selection.properties.baseline) {
        return 'Selection is not a text object';
    if (selection.parent.constructor !== Story) {
        return 'Sorry only simple text frames currently supported (No tables)';
    tf = selection.parentTextFrames[0];
    if (tf.constructor !== TextFrame) {
        return 'Sorry only simple text frames currently supported (No paths)';
    // Not dealing with character rotation or textFrame transformation
    // Will do so in exchange for payment
    ip = selection.insertionPoints[0];
    bound = ip.paragraphs[0].paragraphDirection === ParagraphDirectionOptions.LEFT_TO_RIGHT_DIRECTION ? 1 : 3;
    ipOffset = Math.abs(tf.geometricBounds[bound] - ip.horizontalOffset);
    if (!tabStopProperties) {
        return ipOffset;
    tabProperties = {
        alignment: TabStopAlignment.LEFT_ALIGN,
        alignmentCharacter: ".",
        leader: "",
        position: ipOffset
    if (tabStopProperties.alignment) {
        tabProperties.alignment = tabStopProperties.alignment;
    if (tabStopProperties.alignmentCharacter) {
        tabProperties.alignmentCharacter = tabStopProperties.alignmentCharacter;
    if (tabStopProperties.leader) {
        tabProperties.leader = tabStopProperties.leader;
    p = applyToParagraphStyle ? ip.appliedParagraphStyle : ip.paragraphs[0];
    tabListLength = p.tabList.length;
    p.tabStops.add(tabProperties);
    if (tabListLength === p.tabList.length) {
        // Basic paragraph style - couldn't add tab spot to style so add it to paragraph
        // This will also get set if the tab position already exists
        ip.paragraphs[0].tabStops.add(tabProperties);
    return ipOffset;
function setTabStop(tabStopProperties, applyToParagraphStyle) {
    return getTabStop(tabStopProperties || true, applyToParagraphStyle);
alert('get position: ' + getTabStop());
//alert(setTabStop());
var props = {
    leader: "."
alert('set position: ' + setTabStop(props, true));
HTH
Trevor
Jun 05, 2017 Jun 05, 2017
This is good, but with the table or in other special positions is the main part of the problem I have yet to.
