Enable Multi-Page selection function has disappeared, how do I enable it?
Hello,
Sorry for the delay in response.
Is it possible to elaborate your question? Let us the current version you are using of Acrobat and which version you were using before where the feature was available.
Will be waiting for your response.
-Tariq Dar.
I use Adobe Acrobat DC, and was using it when this feature disappeared.
You can select multiple pages.
In the Left Hand panel, select Page Thumbnails or...
...in the Right Hand panel, choose Organize pages.
If the Organize pages button has disappeared, start to type it the word in the search box and click the panel name.
Alternatively, click "Tools" in the top bar and start to type "Organize". When it shows up, click Add to add it to the RHP.
(Mine does not say Add because it is already added.)
Enable Multi-Page function still does not appear even when Organize pages is selected. I use Adobe Acrobat Pro-DC. I was using Adobe Acrobat Pro-DC when Enable Multi Page selection disappeared, so it used to work with Adobe Acrobat Pro-DC.
What happens when you select multiple pages?
I am only able to select multiple pages by holding down the control key at the same time.
At Tools > Organize Pages you can select odd, even, and all pages. You can select a range of pages. You can use the shift or ctrl key. You can use the lasso function.
I enclose a screenshot of what happens when I select organise pages. As you'll see from the screenshot, enable multi-page selection no longer appears in the bottom left hand corner of the screen which it used to, so I don't have to hold down Control to select more than one page.
There is no option named "enable multi-page selection".
