My Lightroom (which has been updated to 6.10.1 in the hope of improvement) becomes gradually slower during use. It has always been slow to step between modules or even between pictures within a module but I have been attempting to keyword approx. 700 photos in a catalogue of around 3000 and find that after half a dozen or so performance drops. How far? well taking a few seconds to responding to clicking on another photo in the library gallery view. This performance continues to worsen until lightroom becomes unresponsive.
If I remember and exit lightroom before it becomes a problem I can restart with no issues but if I don't eventually the machine becomes unresponsive and only a hard reboot sorts it.
I have checked and during these issues I have plenty of free memory & disk. None of memory, cpu or disk appears to be particularly challenged and none of the other software I am running is affected - it is lightroom only up to the point it's unresponsiveness slips over into locking my whole session.
I have tried the suggested affinity setting to 4 cores - which is an inadequate solution as I have those additional cores for a reason but luckily I can see that all 8 are in use and the 2 exports I am running are working just fine so that doesn't help it seems- so some activities appear unaffected.
Oh and if anyone checks they won't find Lightroom registered to this account, I have finally found, having tried 2 Pcs, 1 android tablet and 4 browser products that a work around to the "too many redirects" issue that appears to work is a new account.
Please help! Product is not performing as expected to the extent that I had to try Olympus Viewer again and for those who know the product that will explain how desperate things have become.
thanks
System info below :
Lightroom version: 6.10.1 [ 1117303 ]
License: Perpetual
Operating system: Windows 10
Version: 10.0
Application architecture: x64
System architecture: x64
Logical processor count: 8
Processor speed: 3.3 GHz
Built-in memory: 16367.2 MB
Real memory available to Lightroom: 16367.2 MB
Real memory used by Lightroom: 3912.0 MB (23.9%)
Virtual memory used by Lightroom: 4516.0 MB
GDI objects count: 479
USER objects count: 1684
Process handles count: 4813
Memory cache size: 3786.5MB / 3835.8MB (98.7%)
Maximum thread count used by Camera Raw: 8
Camera Raw SIMD optimization: SSE2,AVX
Camera Raw virtual memory: 3418MB / 8183MB (41%)
System DPI setting: 96 DPI
Desktop composition enabled: Yes
Displays: 1) 2560x1440
Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
Graphics Processor Info:
AMD Radeon HD 5700 Series
Check OpenGL support: Passed
Vendor: ATI Technologies Inc.
Version: 3.3.13399 Core Profile Context 15.201.1151.1008
Renderer: AMD Radeon HD 5700 Series
LanguageVersion: 4.40
Application folder: C:\Program Files\Adobe\Adobe Lightroom
Library Path: K:\LightroomCatalogs\2017\2017\2017.lrcat
Settings Folder: C:\Users\Chris Page\AppData\Roaming\Adobe\Lightroom
Installed Plugins:
1) 500px
2) DxO OpticsPro 11
3) DxO OpticsPro 11 Importer
4) Facebook
5) Flickr
6) HDR Efex Pro 2
7) LRHaze
8) ON1 Effects Free 10
9) Perfect Effects 9
Config.lua flags: None
Adapter #1: Vendor : 1002
Device : 68b8
Subsystem : 1482174b
Revision : 0
Video Memory : 1010
Adapter #2: Vendor : 1414
Device : 8c
Subsystem : 0
Revision : 0
Video Memory : 0
AudioDeviceIOBlockSize: 1024
AudioDeviceName: AMD DP Output (AMD High Definition Audio Device)
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 48000
Build: LR5x8
Direct2DEnabled: false
GL_ACCUM_ALPHA_BITS: 0
GL_ACCUM_BLUE_BITS: 0
GL_ACCUM_GREEN_BITS: 0
GL_ACCUM_RED_BITS: 0
GL_ALPHA_BITS: 8
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 2048
GL_MAX_TEXTURE_SIZE: 16384
GL_MAX_TEXTURE_UNITS: 8
GL_MAX_VIEWPORT_DIMS: 16384,16384
GL_RED_BITS: 8
GL_RENDERER: AMD Radeon HD 5700 Series
GL_SHADING_LANGUAGE_VERSION: 4.40
GL_STENCIL_BITS: 8
GL_VENDOR: ATI Technologies Inc.
GL_VERSION: 4.5.13399 Compatibility Profile Context 15.201.1151.1008
GPUDeviceEnabled: false
OGLEnabled: true
GL_EXTENSIONS: GL_AMDX_debug_output GL_AMDX_vertex_shader_tessellator GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_pinned_memory GL_AMD_query_buffer_object GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trace GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_transform_feedback3_lines_triangles GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_tessellator GL_AMD_vertex_shader_viewport_index GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_bptc GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_OES_EGL_image GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
Are you doing lots of brushing and/or spot healing on individual photos?
Do you have the GPU acceleration turned on or off? (Preferences->Performance Tab->Use Graphics Processor checkbox)
In these instances I have been working through just doing keywords, there are inevitably the odd tweak I make as I work through but essentially keywording is the last part of my workflow so trying to work through the gallery in batches of pictures (my keywording strategy is largely "who" and "where" for my own benefit so batches of pictures works nicely).
I have tried both with and without GPU acceleration - my card has 2Gb ram but it's probably not worth using, it has overclocking facilities built in using Amd Overdrive but the fan spins up / temperature rockets so that either my eardrums will burst or my legs which are next to my PC will incinerate which is a shame 🙂
I have also ensured that my AV is not scanning lightroom.
So last night I did 2 exports at the same time of the 766 odd pictures and that worked fine (I can't tell you if it took "too long" or not - it didn't seem unreasonable, the processor was busy but not max'd out and other activity worked) and I then jumped around modules and was investigating using rammap to see if there was an obvious leak and found nothing from just navigation activity.
It doesn't sound like you have answered my question: "Are you doing lots of brushing and/or spot healing on individual photos?"
In the instances where I have had a notable problem I have been working through just keywording with the odd tweak where I spot something missed : so no. I don't normally anyway.
I have the same issues, 32gb ram, m.2 ssd drive, 5820 6 core proc and I have to exit and reopen LR about once an hour or it slows down to the point it is unusable. It starts kind of blinking and pauses and then a force close is needed or sometimes even a full system reboot.
THere are many reports of 6 core CPUs performing slowly in Lightroom. The solution is to force LR to use 4 cores, and if you search this forum, you can find the exact method of doing this.
I've seen that limited the cores suggested as a solution but I've tried it and it made no difference but even if it did it's may be a temporary workaround but it is not an acceptable solution. It really is time that adobe put some effort in and resolved the problem.
I have the same problem. I have a powerful machine (380 GB RAM, 2 intel proccessors 8 cores each) and LR (2017 release) slowes down as I work. I noticed that LR uses more and more memory while working. Each next photo takes 100 MB more. When reaches 10 GB of memory it is already slow. Simple commands, even changing a photo, takes several seconds. When I exit LR I observe that memory is slowly released. (I use system monitor fot this)
I think LR or Windows 10 cannot manage such amout of memory for the program (other programs work without troubles, in the same time). Seems to be a problem with software - LR or Windows 10. I still have plenty of RAM, processors are of almost no use, but LR is critically slowing.
I have tried some tricks - turned off and on the use of Graphic Card Processor, tried different values of Camera Raw Cache Settings. I also switched the monitor from 4K to HD. These makes no effect. The only soution is to exit Lightroom every 10 minutes.....
I use also LR 5 on a MacBook Pro (middle 2012) and it works great.
Same problem here - Lightroom worked fine on my PC for almost two years, I could work for hours on end with no slowing down, and now since about two weeks ago I've had this issue. I've tried several things to improve performance - increasing the cache seems to buy me some time and the slow-down sets in a bit later, but so far I haven't found a solution.
Very frustrating, fix this quick, Adobe!
