I'm having an issue with when typing text say for a logo and the text types on top of itself after I hit return. It will not go to the second line...just keeps repeating itself. I just had an update and it still does this. Can't figure out what to change...thanks for any help.
On the Type tool's option bar on the right, look for a box with lines in it. Click on it to reset the tool. That may fix it.
If not, reset global preferences to default. To do that, go to Edit menu>Preferences>General and look for this:
Hi barbarar,
Thanks for posting in Adobe forum.
I understand you are facing issue with Text Tool in Adobe Photoshop Elements.
Could you please try the following steps:
Firstly,
- Open Photoshop Elements
- Click "Edit"
- Click "Preferences"
- Click "General"
- Click " Reset preferences on the next launch"
- Re-open the program & test "Text Tool" again.
If this doesn't help you then secondly,
- Select "Text Tool" from the toolbox.
- Click the to open the menu in Tool Options.
- Click "Reset Tool" or "Reset All Tools"
- Restart Adobe Photoshop Elements & test "Text Tool" again.
Hope this helps you.
Regards
Dhananjay
MODERATOR
This has nothing to do with the stamp tool. OP is having problem with TYPE tool. Waiting to hear back from OP.
