I have been having issues with getting Lightroom 2015.09 and now 2015.10 to allow me to select the rating on photos. As soon as I start the process the program shuts down on me and crashes. I ran 2015.09 and haven't had problems until recently. The upgrade to 2015.10 hasn't help.
Graphics card is updated and there are not issues with the card.
This does work ok when I turn the graphic processor off =(
Thoughts?
Kenny
Thoughts?
Kenny
Then turn it off and leave it off. If you aren't using a 4 or 5 K monitor the GPU option only slows down LR and as you have found out can cause other problems.
Hi Kenny,
which graphics card are you using ?
Have you tried an older driver for your graphic card?. Sometimes it's better to use an older driver because the newest one can be buggy or does have incompatibilities with other software.
Otherwise let the GPU acceleration deactivated. In normal case you don't notice a significant difference of speed.
Axel
Thoughts?
Kenny
