I recently was trying to edit with after effects with audio. I drag the audio in and hit space bar. The audio plays but it is sped up (although somehow keeps the same time, I have no idea how) and is in a much higher pitch. I would try to render it and see how that goes but I get a different problem saying that Media Encoder is not installed (which it is, and I know this as I have rendered with it before) But that is a different problem.
Any help is appreciated.
Nobody can tell you anything without exact system info or other technical details such as exact version of AE, comp settings, preview settings, audio preferences and specifics of your audio files.
Mylenium
Ah, just realised I forgot to add it in at the end.
Adobe After Effects CC 2015
AE Version: 13.7.1.6
Comp Settings: 1280x720, Frame rate - 24, full resolution, 5min duration
Audio File details: 3mins 20secs 44.100 kHz/Stereo
(There might be some unnecessary info in there, apologies.)
And what are your preview settings on teh respective panel? The audio preferences?
Mylenium
This probably sounds stupid but, where do I find the audio preferences?
Edit --> Preferences --> Audio and Window --> Preview
Mylenium
For the record, this sort of thing is a lot less buggy in the CC 2017 release.
Cant seem to see Audio and window?
He was saying two different things. He was saying screenshots of both of the audio preferences would probably help (Audio Hardware and Audio Output Mapping) and he was asking for a screenshot of your preview panel (Window>Preview)
Hi HarryH,
Are you still facing this issue? Please let us know if you still need help.
Kevin
