Whenever I try to start Acrobat Reader DC it gets an error. Below is the information from the event viewer. I have uninstalled and reinstalled acrobat and that does not solve the problem. I'm running Windows 10 64 bit with the latest updates. I've searched this forum and found other instances of this problem but no viable solutions.
Faulting application name: AcroRd32.exe, version: 17.9.20044.25828, time stamp: 0x58e4302d
Faulting module name: lockpdfu.dll_unloaded, version: 12.9.3.0, time stamp: 0x57990936
Exception code: 0xc0000005
Fault offset: 0x000190f7
Faulting process id: 0x4478
Faulting application start time: 0x01d2bac07e2b2ee2
Faulting application path: C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe
Faulting module path: lockpdfu.dll
Report Id: 8eb2bd2b-7936-49d5-8807-b33563f211f6
Faulting package full name:
Faulting package-relative application ID:
Found the problem - caused by PDF Ownerguard package.
Hi Rickm85914334,
Thanks for sharing the detailed information.
As mentioned above, that you have already tried uninstalling and reinstalling acrobat. Have you also tried resetting the preferences of Acrobat?
If not, then you may refer to the help document and try the resetting the preferences of Acrobat as suggested in 2nd solution.
Resolve Acrobat DC intermittent crashes on Windows
Let us know if it still doesn't work.
Akanchha
Followed suggestion in the second solution and it did not fix the problem. Latest error from the event viewer.
Faulting process id: 0x19c8
Faulting application start time: 0x01d2bb60ca40deda
Report Id: 31cf8d07-43ae-4844-987e-d20f30976b13
Thanks for letting us know the exact problem.
Glad to hear that worked for you.
-Akanchha
I have the same issue.
Faulting module name: explorerframe.dll, version: 10.0.14393.953, time stamp: 0x58ba588b
Exception code: 0xc0000008
Fault offset: 0x003d9d2a
Faulting process id: 0x464
Faulting application start time: 0x01d2d945f784cd44
Faulting module path: C:\windows\system32\explorerframe.dll
Report Id: 81debe9e-1c11-4228-8d35-0d3d19790111
Windows 10 Enterprise with latest update. I tried the fixes listed in the recommendation above, the issues persists.
