I run a 2-monitor system with the latest Mac OS 10.12.5 (iMac late 2015, 3.3 GHz Intel Core i7, 16gb ram) and the current Adobe InDesign 2017 software. I keep my pallets on the second monitor (Viewsonic VX2370). I have had the setup for about a year. The second monitor is connected to the iMac with an Insigniaâ„¢ - Mini DisplayPort-to-HDMI Adapter to an HDMI cable.
When I move my cursor over to a pallet to select something it gets really hesitant, draggy or jumpy. It's frustrating to move into the pallet area as it delays the movement of the cursor. Once I am out of the pallet area on the second monitor or move the cursor to the main monitor it moves as it should.
I have changed the settings for the monitor in the preferences which doesn't change the problem. I have researched the problem on the web and haven't found anything related to the problem.
I have been through all the Mac OS updates since I purchased the iMac in June 2016. I don't have any cursor dragging with any other software only Adobe. I use InDesign, Photoshop, and Illustrator the most with all 3 doing the same thing.
I am asking if anyone has had this problem or knows of a solution.
Thank you,
Rick
Hi Rick Soldin,
If I get you query correctly, while using pallets on second screen cursor is jumping on InDesign, Illustrator and Photoshop?
Try turning off GPU performance .
Regards
Srishti
I had the GPU off for a couple of weeks while Apple fixed the video problem that was related Adobe problems. Turning it on and off doesn't make a difference in the movement of the cursor.
Hi Rick Soldin,
Could you please confirm which graphic card you are using and when it was last updated ?
Regards
Srishti
Hi Srishti,
My iMac has the Intel Iris Pro Graphics 6200 1536 MB in it.
Rick
