SOLVED
Solr Integration - custom implementation vs ootb oak solr Index
Avatar
Level 5
Hello,
What would be the pros/cons of a custom solr integration implementation vs using solr oak index?
By custom implementation, I mean using the solrJ APIs to index and search for content or doing something similar to what's outlined in this link:
https://helpx.adobe.com/experience-manager/using/aem_solr.html
By oak index, I mean what's given in this link:
http://jackrabbit.apache.org/oak/docs/query/solr.html
One con of using the oak index seems to be that the developer has no control over whether the solr or lucene index will be used since it seems to be based on cost calculation done by jackrabbit. But this seems avoidable by having only solr indexes in the repo.
Any one have any other thoughts on this?
1 Accepted Solution
Avatar
Correct answer by
Level 9
jakej40603950 wrote...
That is default behaviour, In your custom component use native query so that you can specify to pick solr index only.
Avatar
Administrator
Please have a look at this fourm post:- http://help-forums.adobe.com/content/adobeforums/en/experience-manager-forum/adobe-experience-manage...
// It talks about internal search vs external search +  Lucene VS Solr Vs 3rd party.
Comment for Opkar :-
If you wanted to do Federated search, then you should do that with an external search engine, you don't want to be pulling content from other sites into AEM to do federated search. If you wanted to do semantic or natural language search, then you would need an external search engine(there are some other features not available with OOTB search).
External search engines are good if all the content is public, as enabling ACL's can become complicated and take time, if you use the OAKSOLR integration, then this does apply ACL's to solr content.
With an external search engine, you obviously have the latency of making a call to the external search engine and pulling the results, depending on the network latency, this may or may not be an issue for you.
I hope this would help you.
~kautuk
Kautuk Sahni
Avatar
Correct answer by
Level 9
Avatar
Level 5
MC Stuff wrote...
Thanks. By native query - you mean jcr-sql or xpath? If you could elaborate on how to specify which index to pick that'll be great!
