Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
SPA & Adobe Target Implementation
Avatar
Level 1
We have a client where we need to deploy Target across their Angular UI-router SPA.
We’re struggling on setting this up on our sandbox to test the deployment, we’ve added a demo Angular site https://yamahaclub.com/angular-test/ to set Target up on before we start the client work.
 The Adobe documentation isn’t consistent, one says you need a manual mbox one doesn’t.
  1.       https://github.com/Adobe-Marketing-Cloud/target-atjs-extensions/wiki/Angular-UIRouter
  2.       http://adobe-marketing-cloud.github.io/target-sdk-libraries/demos/examples/angular/state_change_demo...
One of the guidelines say to use at.js without the auto-created mbox but doesn’t say why, can we not use the auto mbox at all?
If the site has a static component and an SPA, do we need to change the tool instance to use a manually configured mbox?
Do we need to manually create a DTM rule with the ‘adobe.target.ext.angular.initStates’ for every app and module in the SPA we want to test or are we able to somehow have a global one?
Also will this work for SPAs where the URL doesn’t change or have fragments.
e.g.
https://domain.com/angular-test/#/home/paragraph
https://domain.com/angular-test/#/home/list
vs
1 Accepted Solution
Avatar
Correct answer by
Level 2
Hi Alex,
I know this post is a little old, but have you looked at at,js 2.0 recently. The 2.x versions were built specifically for handling SPA's
How at.js works overview
1 Reply
Avatar
Correct answer by
Level 2
Hi Alex,
