I am setting up my first campaign(s) in Target (formerly used Target Classic) and I am having some trouble setting goal metrics. I have a 50/50 test using a global mbox, and my goal needs to be when a specific page is visited. the issue I have is that my URL's are not fixed, for example:
https://pet1.johnlewis-insurance.com/quoteAndBuy.do?e=e1s1&curPage=paymentMonthly
as opposed to
https://pet1.johnlewis-insurance.com/quoteAndBuy.do?curPage=paymentMonthly
So I was trying to set a rule saying
Conversion > viewed a page > where URL contains > &curPage=paymentMonthly
but I don't think this is working correctly (numbers are too high) - we have other pages in other implementations with the same &curPage parameters, so I suspect I may be tracking these as well??
I guess I need to do something like:
Conversion > viewed a page > where URL contains > https://pet1.johnlewis-insurance.com/quoteAndBuy.do? AND &curPage=paymentMonthly
IS this possible? If not, can you suggest a workaround? I can't be the first with non-static URLs...
Solved! Go to Solution.
Hi there,
Assuming you have global mbox on dynamic pages, you can select Conversion metric and then Viewed an Mbox where you can define an audience which qualifies for this success metric. While defining Audience, you can add AND based rules on Current Page URL contains.
Another solution is using A4T - Analytics for Target, though this will require you to upgrade Analytics version and add Marketing Cloud Visitor ID service on your site. I'll strongly recommend it as it takes away pain of setting up metrics beforehand and helps in getting single version of truth.
Hope this helps,
Rajneesh
Hi ,
It's not possible to add "AND" operator in the URL contains condition . You can check Multiple URL condtions using "OR" operator only. Hence We would suggest to add all the URL's in the URL Contains condition using "OR" operator like below
Thanks & Regards
Parit Mittal
Total Likes
Hi there,
Hope this helps,
Rajneesh
