SOLVED
Auto Save in AEM adaptive forms not working.
Avatar
Employee
I am trying to configure AEM adaptive forms for Autosave functionality as per the document. But I am facing an issue with it. I configure it correctly for time based autosave but still its not working. The data is not being stored automatically but if I click on the save button at the bottom of the form it gets saved.
Any idea if it is a product bug or if I am missing something ?
Samir
1 Accepted Solution
Avatar
Correct answer by
Level 7
Old question, but I had a similar problem. I tried putting a value of "elementValueChanged" as the event but that didn't work. I worked around this with the following client library on my form:
window.addEventListener("bridgeInitializeStart", function (evnt) {
  // get hold of the guideBridge object
  var gb = evnt.detail.guideBridge;
  //wait for the completion of adaptive forms
  gb.connect(function () {
  //this function will be called after adaptive form is initialized
  gb.on("elementValueChanged", function (event, data) {
  // When a field is changed - save
  gb.trigger("guideAutoSaveStart");
Although this works as I would like, I would be interested to know why an event of "elementValueChanged" didn't work. Does anyone have an example of autosave without a client library using an event?
Avatar
Level 2
Did you try it for event based ? Can you please share the configuration you used for autosave.
The documentation for auto save is present at - https://helpx.adobe.com/aem-forms/6-1/auto-save-an-adaptive-form.html
Gaurav
Avatar
Correct answer by
Level 7
