SOLVED
Error when testing Forms using FormsIVS - org.omg.CORBA.MARSHAL: Exception waiting for response
Avatar
Level 1
We have a Weblogic 12.2.1 server cluster on Linux 6.7 with JDK 1.8 and have installed and configured AEM 6.2 Forms. When we try to test the installation using the FormsIVS application we get the following error
An error occurred while processing your request
org.omg.CORBA.MARSHAL: Exception waiting for response; nested exception is: java.io.EOFException: endOfStream called by muxer connected to /127.0.0.1 vmcid: 0x0 minor code: 0 completed: No
On the server we don't see any XMLForm porcess getting created and we see errors like below in the weblogic server log file
####<Aug 29, 2016, 9:58:20,882 AM PDT> <Error> <com.adobe.service.ProcessResource> <lgp2pdfg1.calpers.ca.gov> <ENV50_aem_node1> <[ACTIVE] ExecuteThread: '13' for queue: 'weblogic.kernel.Default (self-tuning)'> <<anonymous>> <BEA1-57880EBBC3BD2F446D47> <da5bdaf0-b2b1-41dd-b9f8-391ededf19e7-0000009a> <1472489900882> <[severity-value: 8] [rid: 0] [partition-id: 0] [partition-name: DOMAIN] > <BEA-000000> <ALC-BMC-001-031: An unexpected CORBA exception occurred while  allocating a connection by service XMLFormService
        at weblogic.iiop.Utils.mapRemoteToCORBAException(Utils.java:832)
        at weblogic.iiop.Utils.mapToCORBAException(Utils.java:876)
When I try to run the XMLForm command on the command line I get the following error
system exception1330446337
            Unknown Exception in doFlush()
Tried using http://blogs.adobe.com/livecycle/2011/11/debugging-form-rendering-issues-related-to-xmlforms-native-... but does not give much info. All the libraries and linked etc.
The same seems to work on Weblogic 12.1.3 with JDK 1.7 but the documenation says Weblogic 12.2.1 and JDK 1.8 is a supported platform.
Has anyone encountered this?
Atul
1 Accepted Solution
Avatar
Correct answer by
Level 1
We resolved this issue by changing the fonts location from a shared NAS file system to local directory on each managed server in the cluster.
Atul
1 Reply
Avatar
Correct answer by
Level 1
Atul
