Learn about Edge Delivery Services in upcoming GEM session
SOLVED
scp command in command line step of the workflow
Avatar
Level 2
how to give scp command in command line step of workflow to copy a file from server.need to give username and password in the same command .
i have already tried the following commands :
scp ${file} USERNAME@pqrs.xyz.com desktop/xyz
scp ${file} USERNAME:'PASSWORD'@pqrs.xyz.com desktop/xyz
And getting the following exception :
org.apache.commons.exec.ExecuteException: Process exited with an error: 1(Exit value: 1)
    at org.apache.commons.exec.DefaultExecutor.executeInternal(DefaultExecutor.java:346)
    at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:149)
    at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:136)
    at com.day.cq.dam.core.process.CommandLineProcess.execute(CommandLineProcess.java:235)
    at com.day.cq.workflow.compatibility.CQWorkflowProcessRunner.execute(CQWorkflowProcessRunner.java:93)
    at com.adobe.granite.workflow.core.job.HandlerBase.executeProcess(HandlerBase.java:208)
    at com.adobe.granite.workflow.core.job.JobHandler.process(JobHandler.java:140)
    at org.apache.sling.event.jobs.JobUtil$1.run(JobUtil.java:365)
    at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
    at java.lang.Thread.run(Thread.java:680)
but somehow i am not able to copy it .
please let me know if you have any idea about the respective issue.
Saurabh :)
1 Accepted Solution
Avatar
Correct answer by
Level 10
There are various ways like Using public keys without a passphrase  OR sshpass Or Expect . Check with your network team they will help with exact command.
Avatar
Level 10
Refer scp documentation. The parameter supplier is wrong that the after hostname you will have colon with path and there is no space.
Avatar
Level 2
hey sham,
Thank you for your reply , it will be very helpful if you could give syntax  for it .
Saurabh
Avatar
Correct answer by
Level 10
