Hello.
What are the methods to gradually increase transparency of an object (by "object" I mean any area of interest of an artwork). Say I have a black rectangle. I want the upper half of the rectangle to be solid black, and then from the middle I want it to become more and more transparent, right to the bottom edge. If there is some way to make Gradient Tool to affect transparency, that would be great. Any ideas?
Add a mask.
Where the mask is white the pixels on that layer show.
Where the mask is black the pixels are transparent
Grey is semi-transparent
So if you add a mask and use the gradient tool to make it go from black to white you will get the effect you want
Dave
Add a mask.
Dave
Blimey Dave. It must be 1.15am over there. You don't want to be skimping on your beauty sleep matey
fantastic. thank you Dave and Trevor.
You can apply gradients to Layer Masks. In fact you can do most things in layer masks, but you are restricted to grey scale.
Does that help?
