SOLVED
Page properties
Avatar
Level 2
Hi, is there any way to persist page properties in Crx on page creation?
I've created some properties but only after opening dialogs and save i obtain values in crx and can manage some logic into the page.
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
at which point are these properties available? When the properties are parts of the templates, you can attach them to the template (at page creation the template is copied over to the right location).
regards,
Jörg
Avatar
Level 9
CQ5  uses wcmcommand name createPage to create a page with default properties. If you have fields or properties in dialog, it won't be created until you open the dialog and hit OK button.
In order to have you persist data when creating the page you need to write custom wcmcommand which will be writing a custom java class to perform the action you need.
Your question is similar to the following post, please review the responses
https://forums.adobe.com/thread/1189446
Avatar
Correct answer by
Employee Advisor
regards,
Jörg
Avatar
Level 2
Thanks.
This seems the easiest way.
