SOLVED
How to extend sling postservlet in aem for ok button in dialog.
Avatar
Level 2
After inserting data into dialog it should  save the value in some other location not in /content /pagename/componentname
1 Accepted Solution
Avatar
Correct answer by
Level 8
save : function() {
            var config = {
                url: 'path to servlet',
               ,success: function(){
                    CQ.Ext.Msg.show({
                        title : CQ.I18n.getMessage('Success'),
                        msg : CQ.I18n.getMessage('successfully .'),
                        buttons : CQ.Ext.Msg.OK,
                        icon : CQ.Ext.Msg.INFO
                },failure: function(){
                    CQ.Ext.Msg.show({
                        title : CQ.I18n.getMessage('Error'),
                        msg : CQ.I18n.getMessage('Save failed, check logs.'),
                        icon : CQ.Ext.Msg.ERROR
constructor : function(config) {
             config = CQ.Util.applyDefaults(config, {
                resizable : false,
                float : false,
                draggable : false,
                minimizable : false,
                closable : false,
                plain : true,
                layout : "form",
                hidden : false,
                padding : "20px",
                style : {
                    position : "inherit",
                    zIndex : "auto",
                    left : '0px',
                    top : '0px'
                x : 0,
                y : 0,
                defaults : {
                    layout : "form"
                disabled: this.readOnly,
               formUrl : url,
                responseScope : this,
                buttons : [ {
                    text : "Save",
                    handler : this.save,
                    scope : this
                buttonAlign: "right"
Avatar
Administrator
Hi
Same type of question as asked on our older thread :
Link:- https://forums.adobe.com/thread/1170252
//The article covers, How to custom the ok button in the edit dialog
         you have to add cq:editConfig node to your component and define the cq:listners node with what ever the event you want. Please refer below link
        http://dev.day.com/docs/en/cq/current/developing/components/edit_config.html#cq:listeners
        Now here you have many events and based on your requirement either you can use client side event (means java script events to track the information for example before/after <action> event from         http://dev.day.com/docs/en/cq/current/widgets-api/index.html?class=CQ.wcm.EditBar or http://dev.day.com/docs/en/cq/current/widgets-api/index.html?class=CQ.wcm.EditRollover
        OR
        you can write your own handler which will help you to do you task, the benefit here is that you will have all the CQ API available to do your job mainly fetching user information from current session.
        http://sling.apache.org/site/eventing-and-jobs.html
        but its your choice which best suits to your requirement.
        Also if you select client side even handler then ecma script will help you to fetch user information for example take a look at /etc/workflow/scripts/activitystreams/dummy-activity.ecma
I hope this might help you.
~kautuk
Kautuk Sahni
Avatar
Correct answer by
Level 8
save : function() {
            var config = {
                    CQ.Ext.Msg.show({
                    CQ.Ext.Msg.show({
                resizable : false,
                float : false,
                draggable : false,
                closable : false,
                plain : true,
                layout : "form",
                hidden : false,
                padding : "20px",
                style : {
                    zIndex : "auto",
                    left : '0px',
                    top : '0px'
                x : 0,
                y : 0,
                defaults : {
                    layout : "form"
               formUrl : url,
                buttons : [ {
                    text : "Save",
                    scope : this
