Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Uncaught SyntaxError: Unexpected token if
Avatar
Level 1
Hello,
I was wondering if anybody is getting the following:  when I try to access the test page in an incognito browser (Chrome), I'm getting a "Uncaught SyntaxError: Unexpected token if".  I tried this with IE and FF but only Chrome seems to be the one displaying the error.  When looking into the error, it looks like the source of the issue is typeof(s_tnt)=='undefined'.  The implementation of Target is standard, so no custom work was done.  If anybody have any insights on how to fix this, please let me know.  I'm including screenshots of the error.
Ridder H. Manzanet
1 Accepted Solution
Avatar
Correct answer by
Level 10
It's hard to tell without taking a deep look into the implementation. I would check to see if any of your other code libraries reference that variable. It might be possible that an old Analytics plug-in is referencing that variable from your s_code/AppMeasument library (if you an Analytics customer). If that doesn't turn anything up, I'd recommend opening a ticket with Target Customer Care. They can gather the necessary details for an in depth look into your implementation.
Avatar
Level 10
Hi Ridder,
Can you tell me if you are using the legacy sc-tnt integration? Typically, that variable is used in the legacy integration which has been deprecated. I'd suggest looking into the newer A4T integration.
Jantzen
Avatar
Level 1
Thanks Jantzen for the quick reply.  The site doesn't have the sc-tnt integration implemented.  Anything else that I should be looking for?
Ridder H. Manzanet
Avatar
Correct answer by
Level 10
Avatar
Level 10
Hi Ridder,
Is the above issue resolved?
Thanks & Regards
Parit Mittal
