Hello
How to add robots.txt file on when i do not have access to production CRDXLite?
Is there any way to add the file through configuration?
Solved! Go to Solution.
The robots.txt file is often a standard part of your site. I'm not sure why we are all recommending workarounds, the right way would be to work with your administrators and create the file.
Opkar
You need access to CRXDE lite to do this. See: http://www.wemblog.com/2013/06/how-to-implement-robotstxt-sitemapxml.html
Total Likes
Hi
As mentioned by Scott, this[1] is good article to start with.
Link:- http://www.wemblog.com/2013/06/how-to-implement-robotstxt-sitemapxml.html?spref=bl
// Go to CRXDE or CRXDE light, Or you can directly put them in your CVS under jcr_root folder. You can create different version of robots.txt based environment and domain name.
Then you can configure sling rewriter (org.apache.sling.jcr.resource.internal.JcrResourceResolverFactoryImpl.xml) under /apps/sling/config to redirect to correct robots.txt or any site specific configuration. More information about configuration can be obtained from here http://www.wemblog.com/2012/10/how-to-work-with-configurations-in-cq.html
For Prod something like resource.resolver.virtual="[/robots.txt:/robots-prod.txt] and for all other env
resource.resolver.virtual="[/robots.txt:/robots-qa.txt]"
Extra reference link:- http://adobe-consulting-services.github.io/acs-aem-commons/features/simple-sitemap.html
I hope this would be helpful to you.
Thanks and Regards
Kautuk Sahni
Total Likes
Access to production publish crxde is disabled for security reasons but you might have access production author crxde where you can create and then replicate it.
Total Likes
Hi
I think you can use this way :
1. Create a field in page properties
ex : you can create a field Robots in page properties of HomePage template. ( the author can update & change it )
2. Under the homepage template.path : \jcr_root\apps\<your-project>\components\pages\homepage, you can create a JSP file or HTML file ( robots.html or robots.jsp to get page properties ( example : ${pageProperties.robotsTxt}
3. You need to rewrite the url RewriteRule ^/robots.txt$ /content/test/home_pate.robots.html [PT]
Thuong.
Total Likes
Why can't you just place robots.txt in your dam?
Then you would not need additional work apart from rewrite the url RewriteRule ^/robots.txt$ /content/dam/test/robots.txt [PT]
Peter
Total Likes
PuzanovsP wrote...
Peter
I agree with this guy. This makes it easier to update and you can restrict permissions to the file.
Total Likes
Opkar
