SOLVED
CQ 6.2 Changes
Avatar
Level 4
I am doing migration from CQ5.56 to CQ 6.2 .
In CQ 5.56: There is repository.xml file in repository folder, where i had to add the line <trusted credential/> for authentication.
Now, As in cq6.2 there is no such files in repository folder. Where to add it?
Is there any change in CQ 6.2?
1 Accepted Solution
Avatar
Correct answer by
Administrator
There is a specific section in the upgrade guide for authentication[0]. There is no config xml files in crx3.  All the necessary available config if any should be in felix console.
The parameter does not make sense in AEM6 because
    Cluster is recommemded to do it Mongo & AEM does not use tar journal in crx3.
    CRX3 cluster with tarmk is not possible & supported.
    If you are using AEM6 with crx 2 still you will still have xml file and can change there.
This can be configured in the Felix console under ‘Apache Jackrabbit Oak AuthorizableActionProvider’ configuration.
Also - read the OAK docs here: http://jackrabbit.apache.org/oak/docs/security/user/authorizableaction.html
[0]https://docs.adobe.com/docs/en/aem/6-1/deploy/upgrade.html
Please have a look at similar post:
Link:- http://help-forums.adobe.com/content/adobeforums/en/experience-manager-forum/adobe-experience-manage...
I hope this would help you.
~kautuk
Kautuk Sahni
1 Reply
Avatar
Correct answer by
Administrator
~kautuk
Kautuk Sahni
