AEM form CRUD Operations
Avatar
Level 3
Hi Experts,
I am using AEM forms for storing some content in CRX (through Submit and Store Action).
Now , I have to do certain operations like Edit or Delete the records within the form. I know AEM suggests to use bulk editor for same but requirement is to perform operations from AEM forms itself.
Any idea ?
Avatar
Level 8
I'd need more detail before I can provide a definitive response.  To edit the content it would be fairly easy to re-render the record into the form and allow the user to make changes.  It would be much like the draft capability in the portal.  For deletion a "listing" UI would have to be created allowing for the selection of the records to be removed.
Avatar
Employee
I agree, using Save and Submit Forms portal functionality should suffice your requirement
Avatar
Employee
Also, in general, you should probably avoid Store Content action for production use because of the PII & Scalability concerns. Please use Form Portal Submit.
We have added few APIs to list the Portal Drafts & Submissions. I do not remember those has delete/edit API though. If not, you may have to use JCR or REST APIs for that.
