I would like to populate a second dropdown box (cq widget, eg xtype="selection") dynamically based on what was selected from the first dropdown via a component's dialog.xml. How do I do this in AEM 6?
For example, I have a country dropdown box, when you select say, Australia, the second dropdown box would populate the states available for Australia. This is only an example, but hope you know what I mean.
Solved! Go to Solution.
Total Likes
Hi Trang,
I hope you will find the following article helpful.
http://helpx.adobe.com/aem-forms/6/dynamically-populate-dropdowns.html
~ Vishal
Total Likes
Hi Trang,
~ Vishal
Total Likes
Sorry, I forgot to mention that this is the dropdown box used by the dialog.xml. In other words, usage of the cq:Widget. For example, I have a component, which have 2 dropdown boxes as stated above.
Total Likes
If anyone else searching for the same problem, I found the solution here:
Total Likes
Thanks Vishal! I will take a look at the link. Cheers!
Total Likes
