Sound Issues
Oct 01, 2008 Oct 01, 2008
When I record and then play a module using the PC speakers, it sounds great regardless of volume level. When I record and then play a module wearing headphones, there is a low buzzing noise (electrical hum) in the background the entire time (regardless of which headphones I use or what volume level I have set). Any ideas on how to solve this (as I do not know whether my users will be using headphones or not).
Thanks in advance,
Recording
1.5K
Hi Karin
Have you confirmed it's the Captivate project? What I mean is to ask if you have tried running the captivate project on different machines and using different headphones. I'm asking because I could fathom the possibility that it's simply an issue with one PC and the headphones.
Cheers... Rick
Oct 03, 2008 Oct 03, 2008
Thanks, Rick. I've confirmed that it's not my headphones and not just on that particular PC. It's a very bad buzz...I cannot publish it sounding like this. :-(
Any other ideas?
Hi Karin
Hmmm, the only thing that comes to mind is to try recording using a different application such as Audacity. See if it records sans the hum. Then import the files into Captivate.
If that seems to work without issue, consider reporting to Adobe as a bug.
Click here to view the WishForm/Bug Reporting Form
Cheers... Rick
Jan 02, 2018 Jan 02, 2018
This problem is still there in Captivate 9 and Captivate 2017.
This is very awful
Kindly, consider this as a bug and fix it at asap.
Also, I want to add one more point, I feel 2017 has some know issues where were fine in C9. Somtimes, captivate behaves very weird.
Thanks in advance!
Could you please be more specific about what audio problem you are seeing here?  It's a little unclear.
If there are other (non-audio related) issues with Captivate, please start another thread that deals with those issues.  It can get confusing for readers of long threads if the title of the thread is not directly related to the discussion.
Nov 08, 2021 Nov 08, 2021
I would like to re-take this issue. I have sounds recorded with Adobe Audition. When played out of Captivate (different devices and different headphones), the sounds are cleaned and without issues. However, when importing them into Captivate I have a couple of issues:
1. There is a static noise before, during, and at the end of several sounds (the sounds are individual words). Has Adobe addressed this issue?
2. I tried to replace sounds. First, I imported a sound (for example, paint). Then, I edited the same sound with the same name and same extension (wav), and imported it (to replace the first sound) into Captivate. The previous sound continues to play. The new sound can't be taken by Captivate. In other words, it doesn't replace the existing sound. I also tried to drag and drop the new sound, but Captivate's library doesn't replace the existing sound.
I'll appreciate suggestions and ways to handle these issues.
Sincerely,
What is the specific bitrate of the audio file you are exporting from Audition?
For compatibility with Captivate it should be 16 bit PCM, not 24 bit or 32 bit.
Oct 10, 2008 Oct 10, 2008
OK, Rick. I have Adobe Soundbooth so I will try that.
Oct 15, 2008 Oct 15, 2008
> great
> background the
> have
> will be
PC speakers are awful. Headphones typically give more complete sound
reproduction. So you are hearing what I'd expect you to hear.
I worked with sound files recently that a colleague recorded. They sounded
fine to her, but hideous through my headphones. Dropping the files into both
Audacity and Soundbooth showed that the buzzing was all in her recordings.
We worked a little to reduce the noise in her recordings, but ultimately I
still had to reduce the noise and normalise the sound with software before
it was usable.
Steve
http://twitter.com/Stevehoward999
Adobe Community Expert: eLearning, Mobile and Devices
European eLearning Summit - EeLS
Adobe-sponsored eLearning conference.
http://www.elearningsummit.eu
Help resources
