Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Query on Recommendations
Avatar
Level 1
I have recently started exploring recommendations engine. I am able to push the data to recommendations engine and retrieve it back via view mbox. I have a use case where in based on a category id passed along with view mbox, I want to see the recommendations which has the same category associated with it. So while creating recommendations activity, I chose 'Most Read Articles in this category' as criteria.
While trying to see the appropriate recommendations, I have the following mboxCreate function call 'mboxCreate('mbox-name', 'entity.categoryId=work')' and I have assumed that it will retrieve recommendations whose category matches with the category I have written in the view mbox but I was wrong because I was seeing some random recommendations present in the collection. So could anyone pls suggest me something so that my use case runs fine.
1 Accepted Solution
Avatar
Correct answer by
Level 10
Hi Gaurav,
Can you please provide your  arget Account credentials as well as the website URL  in a private message so that we can test the Recommendation at our end. However , From First look the Implementation looks to be correct but for further investigation we need account credentials.
Thanks & Regards
Parit Mittal
Avatar
Correct answer by
Level 10
Hi Gaurav,
Thanks & Regards
Parit Mittal
Avatar
Level 10
Hi  Gaurav ,
Is your Issue Resolved? .If not ,Can you please provide your  arget Account credentials as well as the website URL  in a private message so that we can test the Recommendation at our end.
Thanks & Regards
Parit  Mittal
