Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Using profile parameters
Avatar
Level 2
I am working on a POC for calling profile parameters in an mbox, and I see plenty of instruction for how to do this in Target Classic, but nothing in Target Standard. Is anyone doing this now?
1 Accepted Solution
Avatar
Correct answer by
Level 5
Hi Pam,
If you via a mbox (or the API) populate the specific profile field, then you need to refer to it like ${profile.paxType} and if you created the specific profile field via Profile Scripts, then you would use ${user.paxType}.
It is therefore important, that you always know how you are populating the specific field within Adobe Target.
Try that out and let me know if it works :)
Best Regards,
Thomas Løjmann
Lead Architect
eCapacity A/S
Avatar
Level 5
Hi Pam,
Can you share a few more details about what you are trying to do, then I'll see if I can help you.
/Thomas
Avatar
Level 2
Absolutely! The goal of the POC is to use an mbox to load profile parameters for authenticated users into Target, then on another device/browser, after authentication, to use those profile parameters to deliver content [specifically populating an ordering widget]. In a use case we would use dynamic values, but for the POC we are great with static.
e.g., of adding the parameters [per https://marketing.adobe.com/resources/help/en_US/target/target/r_target_behavioral_steps.html]
<div class="mboxDefault">
    <p>Testing adding profile parameters.</p>
</div>
<script>
mboxCreate('test_profiles', 'profile.eVar45=eVar45', 'profile.origin=DAL', 'profile.destination=NYC', 'profile.dateOut=02/12/2017', 'profile.dateRtn=02/12/2017', 'profile.paxType=ADT', 'profile.promo=flyfree');
</script>
It is my understanding that in Target Classic, we would then use something like following code in the offer order to 'show' the profile parameter values: ${profile.origin}
I am not seeing any values passing however.
Avatar
Correct answer by
Level 5
Hi Pam,
Best Regards,
Thomas Løjmann
Lead Architect
eCapacity A/S
Avatar
Level 2
Hi Pam,
Just wanna confirm here , I believe you are adding the script code to your mbox.js file , if not than try that.
For better debugging of mbox call : can you check the mbox trace by adding the url with the below parameter
?mboxTrace=window&authorization="your-authntication-token"
You can grab the authentication token from your marketing cloud by going to  [Target -> Setup Tab -> Implementation on Left Rail ]
Hope this helps .
Arpit Gupta
