Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Target Standard - multi-sourced audience
Avatar
Level 1
I am trying to create new Audience based on two conditions:
- Marketing Cloud Audience criteria
AND
-Target built-in rules (eg. Geo, Network or Browser).
I've tested both separately and each one work's fine.
How to mix these into one Audience?
1 Accepted Solution
Avatar
Correct answer by
Level 10
Hi Kornel ,
This feature is not available at present. However it is there in product roadmap but we can't commit on the timelines for it's availability.
Thanks & Regards
Parit Mittal
Avatar
Level 10
Hi Kornel,
Complex audience definitions use the boolean operators AND and OR to combine rules and parameters to give you detailed control over which site visitors are counted as activity entrants.Please see the following link on creating complex audience in Adobe Target standard.
https://marketing.adobe.com/resources/help/en_US/target/target/t_create-audience.html
Thanks & Regards
Parit Mittal
Avatar
Level 1
ParitMittal wrote...
Hi Kornel,
Thanks & Regards
Parit Mittal
Hi Parit,
Thanks for answer. I knew about combining rules with AND,OR operators, but it works only with rules that are built in Target. My question was about mixing audience that comes from Audience Manager with rules that comes directly form Target Standard into one.
Avatar
Correct answer by
Level 10
Hi Kornel ,
Thanks & Regards
Parit Mittal
